SMD headphone amp, what do you think?
0 Members and 1 Guest are viewing this topic. Read 2900 times.
peranders
« on: 17 Apr 2003, 09:47 pm »
I have finally made my first SMD audio project. It's a headphone amp using OPA627 or OPA134 or AD8610 together with a high speed buffer BUF634.
Works excellent, sounds good also.....
randytsuch
« Reply #1 on: 17 Apr 2003, 11:11 pm »
Looks cool.
Did you design the PWB yourself?
What kind of cans do you use?  I have a pair of AKG 1000's, so a headphone amp does me no good, they need at least a few watts to drive them.
BTW, I stumbled across your website a while ago, and was liked it.
Randy
peranders
« Reply #2 on: 18 Apr 2003, 06:42 am »
1 Thanks!
2 Yes, says so on the pcb :lol: but I haven't made them. They are made in a factory.
3 Sennheiser HD545 reference (quite good)
JoshK
« Reply #3 on: 18 Apr 2003, 04:19 pm »
you are the only other person I have bumped into that owns the Senn 545s.   On the headphone forums I have read that some will prefer it to the 600s because it is a bit more forgiving and easier to push.  I haven't tried the 600s.  I use a McCormack MID headphone amp that sounds great!
peranders
« Reply #4 on: 21 Apr 2003, 06:39 pm »
When I bought these phones I listened to > 20 types, including HD600. I thought then that 545 sounded very neutral. They had no "pop sound". One other fact was that they were on sale 130-150 dollars was price.
harvardian
    • http://www.dipchipelec.com
« Reply #5 on: 21 Apr 2003, 10:19 pm »
Peranders,
How timely! We are adding a headphone output to our PGA2310 version of the APOX-3. We will be using the OPA134 for input buffering into the PGA2310, a opa2132 as a diff amp (balanced->se), then the BUF634. It will taken out of the circuit with relays. What kind of regulators are you using. We are attempting to make the APOX-3 fully dual mono, which means using opto-isolators to keep the grounds separate.
Any other suggestions?
Dale
peranders
« Reply #6 on: 22 Apr 2003, 05:16 am »
I use LM317 and LM337 SMD. You can download the schematics if you want to know more exactly what parts I have used.
« Last Edit: 3 Jul 2008, 08:19 pm by peranders »
