Cable Help
0 Members and 1 Guest are viewing this topic. Read 1390 times.
KeithR
Cable Help
« on: 17 Apr 2003, 07:51 pm »
Well, my Avantgarde Solos should be arriving somewhat soon, and I need some cabling suggestions.  I will use the stock power cords for now, but what I will need is longer interconnects (b/c no speaker cable/active)
Two options-
a) Wadia 861 straight to AGs--XLR, 2.5m prob
b) Cary 306 (or Wadia 861)-->Cary SLP98--RCA to XLR, 2.5 m
Any ideas?  I have a 1m AZ cable I really like, but 2.5m is a fortune of a lot of cables.  Any good bang for the buck cable in this length for this system?  Looking to spend less than 750.
Thank!
KeithR
8thnerve
Re: Cable Help
« Reply #1 on: 18 Apr 2003, 06:36 pm »
Quote from: KeithR
KeithR
Kieth,
We sell Avantgardes and the best bang for the buck cable that I have found is the Audience Conductor (which is what we are using on the Solos in our store) at $210 for 2.5m XLR it is a great bargain.  I replaced Nordost Blue Heaven with the Conductor and the difference was nothing short of miraculous.  We are also using the Audience PowerChords on them as well which made a huge difference as well.  We do sell Audience so I understand if you are skeptical but I chose those cables because I think they sound the best.  If you can find a place to audition them I HIGHLY recommend them.
Best of luck,
Nathan
