Minimum phase for a speaker
0 Members and 1 Guest are viewing this topic. Read 1035 times.
ctviggen
« on: 16 Sep 2005, 11:13 am »
Can anyone point me to a site that explains (particularly, defines) minimum phase for a speaker?  ETF will show minimum phase but does not describe what minimum phase is or how it can be determined.  When I search on google, I get a ton of hits, but many of them are for minimum phase digital correction.
I assume that minimum phase is the smallest possible phase change from input to output, but that doesn't seem correct, as the minimum phase ETF changes relative to frequency.
ctviggen
« Reply #1 on: 16 Sep 2005, 11:15 am »
Never mind!  JoshK had already pointed out a site to me.
konut
« Reply #2 on: 16 Sep 2005, 11:45 am »
Can you post the link please?
ctviggen
« Reply #3 on: 16 Sep 2005, 12:38 pm »
Actually, the link does not describe minimum phase:
http://www.uaudio.com/webzine/2003/december/text/content2.html
It describes linear phase (denoted by "d" in the equations).  The page discusses minimum phase but does not state what minimum phase is.
So, I still do not know what minimum phase is for either a speaker or a crossover.  Since the link says that analog designs cannot produce linear phase but can produce minimum phase, perhaps minimum phase is some quantification of distortion (i.e., nonlinear phase).
KJ
« Reply #4 on: 16 Sep 2005, 12:44 pm »
Found this site.  However, it doesn't necessarily indicate how it would be applied.
-KJ
ctviggen
« Reply #5 on: 16 Sep 2005, 12:45 pm »
Again, I'm wrong!  Dangit!  The third page (in terms of printed pages) does define minimum phase:  minimum phase filters have the least latency for a given magnitude response.
ctviggen
« Reply #6 on: 16 Sep 2005, 12:47 pm »
Thanks, KJ.  Now, that's my kind of site!  Get right to the equations.
JoshK
« Reply #7 on: 16 Sep 2005, 02:13 pm »
Wow, thanks KJ, that is a fantastic reference!  This speaks my language.
What I wouldn't give to go back to grad school there!
_scotty_
« Reply #8 on: 16 Sep 2005, 02:26 pm »
I think for the purposes of realworld loudspeakers and their performance
with respect to phaseshift you will have to ask the loudspeaker to reproduce a recognizable squarewave at a specified frequency. Given the bandwidth
limitations of realworld loudspeakers you will probably have to use Dunlavey's criteria and require that the speaker pass a 1Khz squarewave
with some limits on how far the speaker can deviate from perfection.
In the absence of any criteria defining the phase accuracy of a "minimum phase loudspeaker" the terminology degenerates into just so much marketing hyperbole.
 Scotty
