Industry Circles
Odyssey Audio
klaus@odyssey
Odyssey Speakers And HT
0 Members and 1 Guest are viewing this topic. Read 1780 times.
John151
15 Sep 2005, 04:50 pm »
I am building a HT system for a friend (who is NOT an audiophile). The receiver has will be a Pioneer with 110 Watts into 8 Ohms. I am considering the Odyssey speakers (Nightengale and Nemesis) for this set up. I have two questions with this:
1) Would these speakers work well for a person who is only into the HT aspect? I am seriously wondering if some run of the mill speakers at BestBuy would be a better fit.
2) Would the 4 Ohm impedence be a problem for the Pioneer receiver?
Thanks, John
Eduardo AAVM
15 Sep 2005, 07:40 pm »
For me if you use Odyssey speakers sooner or later your friend will become an audiophile... It is impossible not to listen the difference.
Considering a HT setup has a sub I think you will have no problem, if your friend is bass hungry.
The 4 Ohm situation, that can be a potential problem.
Carlos Villegas
Reply #2 on:
15 Sep 2005, 09:41 pm »
Hi,
The Odyssey speakers are ok and as Eduardo say, sooner or later your friend will be an audiophile !!!
The Pioneer is not a good idea for 4 ohms impedance speakers. Better try with NAD (773 or 763) or Marantz (7500). Some friends in Europe use Dynaudio speakers (4/3 ohms) with NAD and Marantz receivers with excelent results.
Regards
Carlos
Eduardo AAVM
Reply #3 on:
16 Sep 2005, 06:14 pm »
So good to see you here Carlos...
Carlos Villegas
Reply #4 on:
16 Sep 2005, 07:04 pm »
Quote from: Eduardo AAVM
Is nice to see you too Eduardo. Did you see the Klaus post ? The garage sale is not finished !!!
Regards
Carlos
Eduardo AAVM
Reply #5 on:
16 Sep 2005, 07:11 pm »
Not ? I'll check it, I have had some problems accessing some threads in the forum...
jcoat007
Reply #6 on:
16 Sep 2005, 08:38 pm »
Not sure what your budget is, but the Nightingale, Nemesis and Khartago could be the start of great system, if he has pre-outs from his reciever.
I would also think about the Epiphany monitors if he is going to use a sub anyway.
Industry Circles
Odyssey Audio
klaus@odyssey
