VDA1 digital inputs
0 Members and 1 Guest are viewing this topic. Read 1797 times.
sas
VDA1 digital inputs
« on: 15 Sep 2005, 10:34 am »
Dumb question here, sorry in advance, but can't find a answer thru searching or on the CIAudio site.
I thought it would be great to be able to switch inputs -- just like on the benchmark DAC1.
But I see the CIAudio DAC has both coax and toslink inputs, but appears to have no way to switch between the two. Does it mean only one should be connected at a time (meaning lots of cable pulling), or does the unit default to one of the inputs?
CIAudio
VDA1 digital inputs
« Reply #1 on: 15 Sep 2005, 02:47 pm »
The VDA-1 has auto-switching. When signal is present at both inputs, it defaults to the coaxial input. To switch to the Toslink input, simply turn off the coaxial source.
-Dusty-
sas
VDA1 digital inputs
« Reply #2 on: 16 Oct 2005, 12:48 pm »
another question....
The VDA1, VHP1 etc all come with stock wallwarts -- but are these 220v compatible or do non-110v people have to buy the VAC1 upgrade power supply?
CIAudio
VDA1 digital inputs
« Reply #3 on: 16 Oct 2005, 03:17 pm »
The standard version of our small products are 115v only. We don't offer a 230v version because the countries that require 220~240v all use different AC plugs...this would require stocking several models.
The VAC-1 is compatible with these voltages and uses an IEC power cord input, so it can be used anywhere with a simple cord change. Amplifier models are available in 220~240v at no extra charge.
