While better known for a legendary 2A3 amp, there is another Wright that manufactures and sells line and phono stages. The company is Wright Sound and the url is
http://www.wright-sound.com/I have the WPL 11 Phono/Line stage but that is the entry level @ $900. There are more expensive models and there is also a step up transformer, the WMT10, for moving coil cartridges that is adjustable.
The industrial design is kind of "retro" to be kind but the phono section is very nice. I use it with a Decware Select and that amp is very revealing and the WPL11 more than holds up.. The tube complement is kind of esoteric so tube rolling is cheap.
A WPL20 phono/line stage, the more expensive model than I have plus a WMT10 step up tranny would run new less than $1700. Separate power supply module, no IEC for aftermarket PC's but a beautiful sounding unit.
I like mine very much. Fairly easy to deal with for a small manufacturer, not Wayne or Vinnie but decent.
