Migrating a GK-1R to 110V
0 Members and 1 Guest are viewing this topic. Read 1427 times.
Snapper
« on: 12 Sep 2005, 04:33 am »
I will shortly be moving from Canberra, Australia to Calgary, Canada and I'm planning to take my GK-1R with me (along with a yet to be ordered and built AKSA!).
I know that the transformers need to be rewired to cope with 110V as per Hugh's original instructions, but are there other changes I need to make?
Cheers
Mark
AKSA
    • http://www.aksaonline.com
« Reply #1 on: 12 Sep 2005, 07:37 am »
Hi Mark,
In the instructions are diagrams detailing conversion to 110-120V mains;  it's straightforward.
The transformers are wound with grain oriented silicon steel for 100% correct operation in any mains environment.  Originally designed for operation at 50Hz (Australia), the transformers easily accommodate 60Hz as well, and half the supply voltage is just a matter of reconnecting the primaries.
Looking at one of the GK1 transformers, primary tags are(left to right) 0, 115, 0, 115, ES.  For 220/240V operation, you bridge the first 115 tag with the second 0 tag.  For 110-120V operation, you connect the two 0 tags for neutral, and the two 115 tags for active.  ES is connected to chassis and thence to mains IEC earth.
Directions for changing the wiring of the digital control supply are written on the side of the rectangular heatsink and are self-explanatory.  Again, you'll only need to amend the primary wiring;  the secondary output connections are unchanged.
Calgary, huh?  Man, that's colder than Canberra!!  Brrrrrrrrrrr!!!!!!!!!!  At least you'll be lobbing there as summer comes along.  You must look up Bill Perkins, of Pearl, a very knowledgeable fellow who cryo treats tubes and makes tube coolers.
Hugh
Snapper
« Reply #2 on: 12 Sep 2005, 07:47 am »
Thanks Hugh :)  I figured that was all there was to it.
Do you know if I need to change the colour of the power supply wiring to meet the Canadian standard?
Yes, Canberra is a tropical paradise in comparison!  I believe Calgary usually hits -40c during a winter, but the most difficult part may be dealing with rapid changes in temperature ... when the Chinook winds come over the Rockies, the temperature can increase by 30c in 4 hours!
I'll send you my AKSA order as soon as I work out which model I can best afford!
M.
Snapper
« Reply #3 on: 12 Sep 2005, 07:52 am »
Actually, we're getting there at the end of October ... just in time for Winter  :o
