Technical Details of Ah! A/C Offset Killer?
0 Members and 1 Guest are viewing this topic. Read 5458 times.
cjr888
« on: 31 Dec 2002, 04:09 pm »
Product Information Here:
http://upscaleaudio.com/acoffset.htm
Internal Pictures:
http://www.hifi-notes.com/ahacoffsetkiller1-en.htm
Can anyone summarize what exactly this is, and if other products out there include this type of functionality, whether mentioned or not?
Have a friend having hum/buzz issues and trying to assist if I can.
azryan
« Reply #1 on: 31 Dec 2002, 05:50 pm »
This seems like PS Audio's Ultimate Outlet, but using a diff. method of canceling the noise on the line.
PS Audio uses a wound Balum to invert the signal. I don't know the technical details, but it seems to be a pretty simple method.
Shows itself the opposite signal on the power line and the noise will exactly cancel itself.
This one here looks like it's a lot cheaper, so if it works well, that might be a lot better route to go?
The wording on PS Audio's site seems to say that it's unit is also a surge protector and it's totally passive, and doesn't hold back any power at all.
Is this Ah! unit passive?
cjr888
« Reply #2 on: 31 Dec 2002, 06:13 pm »
Not sure, but assuming its passive.
The Outlet has a surge protector in it, and _doesn't_ limit current?  I had always thought that most small typical ones most definitely would.  Am I totally off here?
TheChairGuy
« Reply #3 on: 31 Dec 2002, 06:25 pm »
Guys,
I have a PS Audio Ultimate Outlet (original 15ampmodel) and I STILL have substantial hum/buzz coming from my Norh (bridged) MultiAmps.
It's really annoying on quiet passages.
I've looked at the glowing AudioReview write-ups on the Ah! Offset Killer and have been tempted (especially for the reasonable prices charged) but I simply don't want more boxes behind my gear.
In the case of the Norh's - I think the hum may be R-Core related.  Most amp designs these days have toroidal transformers that are less prone to the 'shakes' if I understand the technospeak right.
Do you know offhand if your friends amp has R-Core of Toroids?  Either way, if he buys the Ah! Offest Killers, please write a review for it.  There must be others on this forum with the same malady.
G-7
« Reply #4 on: 31 Dec 2002, 07:09 pm »
What??
OK,OK. First thing first.
"Most amp designs these days have toroidal transformers that are less prone to the 'shakes' if I understand the technospeak right. "
On the contrary, the toroid is more prone to make a noise. But!!
A properly calculated transformer will never hum, regardless if toroid or EI. If I see a high priced component with humming transformer it makes me run! It's not that difficult to make silent working transformer. With this problem I come to a conclusion that it's just designer lack of knowledge. Hey, and it's just a transformer,
I don't even wanna know more about such a component, what else is wrong there? Think about it.
Hantra
« Reply #5 on: 31 Dec 2002, 07:39 pm »
Is this only a problem with toroids, and lesser quality wound trasformers?  My integrated has 4 massive transformers inside, and they make absolutely no noise whatsoever.
