0 Members and 1 Guest are viewing this topic. Read 2847 times.
For futher details you may refer to our website www.behold-highend.deyou would need the following components:MCA768 AD-Converter on the headshellMCK768 MasterClockUnit to drive the MCA768APU768 main unit housingSDI7678 module to receive the MCK768 audio dataDIO768 module to transmitt the audiodata in S/PDIF format to your TacTbut i must admitt that this will perform highest quality until the audio signal will enter the TacT due to the fact that the 24Bit/768kHz signal will be decreased in quality this way. to keep it at the behold level you should use our BPA768 amplifier or a pair of DAC768 to drive a very high quality analogue final stage amplifier ...rgds Ralf Ballmann
That one does the curve in the analog domain, so it is basically just a phono with built in *probably cheap* ADC. Not exactly the same solution and I'd fear it would be of lesser quality than you and I were looking for.
I asked this same question over on AA and it appears I am not insane.Here it is:For more info...
Every day I get closer to giving up the vinyl thing. I'm going through all my records tomorrow to see how many I'd actually want to hear... and selling the rest. If the collection is less than a couple dozen, I may just ditch the hobby... not sure how I feel about it yet.
