0 Members and 1 Guest are viewing this topic. Read 44333 times.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=211060
shouldn't it be 1.5a??
Thanks for all the repllies, but I'm still confused. Will this PS work for me?
From what I've gathered through this thread and others:1- The 1.5A 5V supplies work fine on the SB2 but the SB3 need 2A
I recently bought a SB3 and noticed the sound quality in my system took a dive I thought a cheapo PS might be a good place to start.
Bob, I would recommend that even given the opportunity that you never listen to either a modded Squeezebox or a higher end power supply ...................
