0 Members and 1 Guest are viewing this topic. Read 44399 times.
The Red Wine Audio mods include a 12 volt battery supply which also provides a 5v regulated supply for the DAC circuits. The power supply for the RWA upgraded SB2 needs to be 12 volts and 1.5amps.Brad
Agentsmith,The ps you linked to is a switching supply. If you click on the picture on the referenced url, from the larger picture, -http://www.pchub.com/uph/catf/BigPicture.aspx?iid=18595&PhotPath=6324537043192187502_ADP-10SB%20REV.DH.jpgyou'll be able to see that the voltage range is specified as 100-240vac, which is indicative of a switching supply. Other than that, even without the specific labeling I'd assume it to be a switching supply given its size. Linear supplies are generally substantially ...
hey occam,can you tell me what ps to get if i have the red wine modded sb2.i have the switch installed to switch between battery and wall wart.thanks for the help.hope to see you at phils.
If that table wart isn't regulated, would this supply, at equivalent price, also from PE, possibly be more appropriate? http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=120-532 .
We realize that the intent of the AC power option on your battery supply is simply for casual background listening, but hey, this is the Lab, where every subject, no matter what, deserves to be obscessively beaten to death.....
Agentsmith,I think Davey's comment was spot on. Indeed one might think that LPS would indicate a linear supply, in the same way that PC hub supplies part number of 'PN: 253628-031 SPS' might indicate a switching power supply. I'm soooooo confused. Regardless, I do believe that quoted input range of 100-240vac as well as the size is compelling (yet circumstantial) evidence that it is a switcher.I'm assuming the link you posted indicates you're in an ASEAN country, and sadly, the availability of surp ...
