0 Members and 1 Guest are viewing this topic. Read 10694 times.
Hi Kevin,Well, ask a busy man to get something done, and it generally does. I've emailed Roger back and forth, definitely a knowledgeable guy. You definitely have enough on your plate. So when I order the deluxe package whether it be the 180 or 400, do you cut out the holes individually for the IEC socket, or because I just want just one socket for both amps, there would be a spot cutout for the 2nd one. Another aproach is to use the one socket, and two on/off toggles. Just a thought.Ray Ray
HI,I recently went to the DIYcable website to get information about the amplifiers, but there is no trace of them on the site. Will you be adding that info?
Kevin,I should have my new speakers done around the time you have your demo unit ready. Therefore, I'd like to be put somewhere near the top of the list for your demo! That is, if you don't already have a long waiting list.
Kevin, thanks for the detailed reply. It sounds like waiting a bit until you get some more bells and whistles developed may be a good thing. I would like to have a minimum of five UcD400AD channels in one chassis because I'm going to be running five full sized Maggies, and I could run my smaller two back speakers later with one of your UcD180AD two channels. How limited in space would a five channel be in terms of being able to go with a bit of overkill on the power supply, transformers, and all t ...
hi kevin,i remember reading from diyaudio's UCD thread to try to make the wires connecting the power supply to the amp modules as short as possible, i'll try to find out why.angelo
Five channels isn't even remotely a problem with the UCD180s. The UCD400s kick out a fair amount more heat though and you have to be much more attentive to cooling them. We are using a large 2" tall aluminum heatsink per two modules at the moment and redesigning our internal air flow so that we have a larger margin of safety for multichannel UCD400 set-ups. The result of this though is it takes up more real estate inside the chassis and you have less room for other things. With five channels we woul ...
We don't have immediate plans. Much of the chassis work requires some machine work and we don't yet have a standard chassis that works for everything without some sort of custom fabrication. What I've found is that DIYers will not pay for a chassis unless it's cheap. The only way to make them cheap is to do a lot of them and standardize on one design. Since our demand for amplifiers is spread out over 2-7 channel amplifiers that causes some difficulty in fiinding a standard design.QuoteHi Kevin, You probably remember the days of the Heath Kit. I think there was $50 to $100 difference between the kit and the assembled product. I do understand your logic in this matter. What sizes of transformers will you be using for the Deluxe version versus 1 transformer for both channels for the plain Jane version?? Don't really know if I've actually hear a difference between both units with one or two transformers. Ray
Hi Kevin, You probably remember the days of the Heath Kit. I think there was $50 to $100 difference between the kit and the assembled product. I do understand your logic in this matter. ...
Yes.... I try to make an evaluation on a case-by-case basis. I'd like to do a general kit based on the Hypex units, as they are easy enough to work with that they are a natural choice for kit building. We might do an easy 2-channel kit that has a customized case but it isn't something that is in our immediate plans.The subjective differences are often subtle when making changes and they are also load dependent. For that reason it's difficult to give people absolute advice.
