Titan Hookup
0 Members and 1 Guest are viewing this topic. Read 1645 times.
rocchi
Titan Hookup
« on: 30 Aug 2005, 09:58 pm »
hello. im looking at getting a new passive preamp but the model im looking at only has 1 set of outputs.  i want to avoid using y adapters to hook up the sub. aci's site suggests using a speaker level connector, but im having problems finding such a device. where to find? any suggestions? alternatives?
my current system-
yba cd 3
msb link dac channel island mods
audible illusions pre
mccormack dna .5 rev a
saphire xl's
titan sub (about 7 years old)
tara interconnects
q-10 speaker cable
thanks!
randy
Rich Carlson
Titan Hookup
« Reply #1 on: 30 Aug 2005, 10:27 pm »
Randy - I think all you need to do is wire up some RCA plugs with speaker wire, and connect them in parallel with your speakers.   There's no specific adapter you need, because of the high impedance of the sub inputs relative to speakers.  A little googling will find you transformers that take speaker level to line level, but I don't think you really need that.
Rich
Mike Dzurko
Re: Titan Hookup
« Reply #2 on: 31 Aug 2005, 12:07 am »
Quote from: rocchi
my current system-
yba cd 3
saphire xl's
tara interconnects
q-10 speaker cable
thanks!
randy
Randy:
Your Titan should have originally shipped with speaker level adapters. They are a male RCA plus with several resistors added and speaker wire on the other end. Give us a call or email [email protected], I don't remember the exact price but I think it is less than $10 each. Check the first hookup on this page to get a better idea:
http://www.audioc.com/library1/subsetupft.htm#stereo
rocchi
Titan Hookup
« Reply #3 on: 31 Aug 2005, 02:51 pm »
thanks!
