Cartridge installation miracle
0 Members and 1 Guest are viewing this topic. Read 1372 times.
randytsuch
« on: 26 Aug 2005, 06:36 am »
OK, so here is my story.
Been putting a turntable together, returning to my roots, if you may.  Have not had a working turntable in maybe 20 years, since someone broke my last cartridge.
So, I am taking the easy way back ;).
Last week, I built a corian plinth.  Mounted the platter from an old empire turntable I bought.
This week, I rewired my rega arm.
And tonight, the miracle.  I finished the rewire, and was installing the cartridge, a Dynavector 10X5.  I had one screw in, so I thought I was safe.  While installing the second screw, the 10X5 somehow came loose, and fell off.
When it started to fall, I knocked it just enough so it landed stylus side up.  I looked at it, and the stylus was still straight, no apparent damage.
When it was falling, I was sure I had just lost $400, I still can’t believe it is OK.
I still have to align it, and then I need to drag my home theater processor out to it, as my HT is the only preamp I have with a phono stage.  Building a new phono stage is my next project.
Randy
Bill O'Connell
  • Retired . Music Lover
« Reply #1 on: 27 Aug 2005, 03:42 pm »
I still break into cold sweats when mounting a cartridge. Just remember the Golden Rule in tonearm/cartridge setup, " Be of sober mind "
 When all is said and done then pour em or smoke em if you got em.
 congrats on the still usable cart.
