0 Members and 1 Guest are viewing this topic. Read 7162 times.
Yeah, it is a little much for a bit of foam and what not with screw holes. Isn't it? Why don't you do a little reverse engineering and see if you can come up with a DIY solution for $15? I am just trying to figure out how to keep the azimuth steady.
"The Isolator is a small rectangular sandwich (3/4 “ W x 1” D x 1/8”H) whose top and bottom are two thin stainless steel plates. Sandwiched between the plates is the exotic, purposed-designed, and very expensive isolating material. This material, technically a closed cell, cross-linked ethylene copolymer structure, is somewhat springy and can be damaged from excessive compression. The Isolator fits between the phono cartridge and the headshell, serving as an acoustic filter between the two. The cartridge side has a re-usable, and easily broken, contact adhesive on its stainless steel plate which bonds the cartridge to The Isolator; two protruding shafts slip into the cartridge’s mounting lugs to center and orient the cartridge. These two shafts do not have nuts; the cartridge is not bolted to The Isolator. From the top of The Isolator protrude two captive bolts that attach to the headshell by two nuts. These nuts are to be tightened just barely enough to keep the cartridge and The Isolator from shifting position."
Constrained-layer damping (CLD) is the application of a “sandwich” construction material that consists of a visco-elastic material bonded with a relatively stiff constraining layer. When the system flexes during vibrational distortion sheer forces are created on the stiff constraining layer. Energy is dissipated through sheer deformation (tensional forces). For a given thickness of material, constrained layer damping will outperform extensional damping. This allows constrained layer damping material to be lighter and thinner in weight. By changing the composition in the visco-elastic material and constraining layer, it is possible to alter the effectiveness of the material over a frequency or thermal range. Typically, the stiffer the constraining layer, the more effective the material. However, stiffer constraining layer makes installation more difficult. Dynamat Xtreme is a butyl composite with aluminum constraining layer, sheet metal vibrational damper. Dynaplate is a aluminum constrained layer damping material with a visco-elastic damping adhesive.
Is it ethically OK to emulate a patented design using readily available, non proprietary material for your own use? I am thinking this is perfectly fine as long as I am doing it for my personal use and not trying to make a profit by underselling the patent holder with a knock off. What is your perspective on the ethical issue of this sort of DIY project?
The 'Isolator' reportedly has a patent on it - I'm kinda' leery about replicating it. It's just a moral issue with me - we have several patents here at my company (many, one in particular hurtful, of my competitors have ripped us off).Basically, it damps the headshell and cartridge body simultaneously - no mystery science to that one. I'm thinking a good not-too-fatty piece of Dynamat cut to the shape of your headshell with provisions for screws would probably do the job nicely
Quote from: woodsyiIs it ethically OK to emulate a patented design using readily available, non proprietary material for your own use? I am thinking this is perfectly fine as long as I am doing it for my personal use and not trying to make a profit by underselling the patent holder with a knock off. What is your perspective on the ethical issue of this sort of DIY project?Slightly off topic, but I was thinking about starting a thread about the ethics of DIYer's copying audio companies and mod ho ...
