I'm digging reel to reel!!
0 Members and 1 Guest are viewing this topic. Read 945 times.
beat
« on: 20 Aug 2005, 03:58 pm »
Hey guys,
Finally got some media for my r2r and checked it out. Really nice! super smooth quiet and full. Of course I'm limited with music choices but I think it is nice to have just to play with and stuff appears on ebay from time to time for little money. It is a two track otari. I figure with it being two track instead of four it gives me twice as much info packed into that 7 1/2 Ips for better sound. Am I right with that thinking? Is this what headroom is? Whatever's going on here I like it nonetheless!
thanks, Beat
3beanlimit
Re: I'm digging reel to reel!!
« Reply #1 on: 22 Aug 2005, 12:45 am »
Quote from: beat
Hey guys,
thanks, Beat
It depends on the tape you buy.  Pre-recorded or not....
I don't remember any 2 channel one direction running pre recorded tapes but that's not to say they didn't make them but I don't think a lot of players could have played them.
Most were 2 channel 4 track tapes.  You ran them one way, then either the machine would play it back the other way on another set of playback heads or you flipped the tape over and played it back.
beat
« Reply #2 on: 22 Aug 2005, 01:58 pm »
Quote from: 3beanlimit
... You ran them one way, then either the machine would play it back the other way on another set of playback heads or you flipped the tape over and played it back....
I believe another name for the type of player I have is 1/2 track or inline-head. It reads the entire 1/4" in one direction and splits the two channels. My understanding of the more common 4 track is that the heads are basically reading an 1/8" each pass instead of the whole 1/4". I could be wrong though. It would be nice to know for sure. What I do know is that it is not easy to find studio recorded media for this puppy.
adios, Beat
SWG255
« Reply #3 on: 22 Aug 2005, 04:20 pm »
It sounds like you have a half-track Otari, very nice for making your own recordings, but I can understand why you can't find much pre-recorded material for it. The "consumer standard" for pre-recorded tapes was quarter-track, where as you said, two tracks are recorded/played back in one direction, and the other two tracks in the reverse direction, or one flips the reels.
If you like the sound of 7.5 ips playback, you might try recording some of your favorite music from CD or vinyl on the machine at 7.5 ips too. The equalization curves for 7.5 ips are very euphonic, and depending on system synergy can be very easy on the ears while retaining good detail, wide bandwidth and reasonable dynamic range.
I used to use my old Revox A-700 as my primary music playback device back in the mid-70's and early 80's, because that saved wear and tear on the old LPs.
Enjoy!
Quote from: beat
I believe another name for the type of player I have is 1/2 track or inline-head. It reads the entire 1/4" in one direction and splits the two channels. My understanding of the more common 4 track is that the heads are basically reading an 1/8" each pass instead of the whole 1/4". I could be wrong though. It wou ...
