0 Members and 1 Guest are viewing this topic. Read 4710 times.
In my quest to understand acoustics, I'm thinking of buying this:http://www.rpginc.com/products/roomoptimizer/index.htmIt looks interesting and should be fun to play with. Anyone use this?
It might take you a while to write it. I did some electromagnetism programs in my EE days, and the time to write the program was large. And the program just spit out data that was unintelligible but to me. The ability to solve these types of equations while also adding in features like couches, RPTVs, non-straight walls, etc. is probably why you don't see another program -- it's intractible.
For 300 bucks including a microphone the Behringer DEQ 2496 will solve alot of problems. My room is LEDE with bass traps but you still have room dimensions and other anomolies enter into the equation. Let this piece do it's thing and then tweak it from there. I will go so far as to say it's an absolute necessity and I will never go without one again. With digital in and out you can even run a separate dac but the dac inside is an AKM 4393 and is a very good dac and sounds good too. I know you guys have ...
Of course, there's only so much that signal correction can do to fix room anomolies by itself, especially in the lower ranges, but the idea made perfect sense to me. Since the price of computing power does nothing but go down, it escapes me why this approach hasn't made more inroads. There are probably engineering and/or market factors that explain it, and if anyone is aware of what they are I'd be interested in reading about them....
It's a modern miracle to high end audio systems for 300 bucks. Just taming the peaks and dips made a huge difference.
...Say you have a middle C of 440hz...
