0 Members and 1 Guest are viewing this topic. Read 3529 times.
OK, I found out what the problem was.."replaygain" was checked in FLAC.Now the volumes are the same. In some quick comparisons using the first song on Eva Cassidy's Songbird CD, I could not tell a difference.Right now the process is:Rip CD to hard drive using EAC. This puts it in a .WAVThen I open Flac and encode to Flac.Is there a one stop deal where EAC rips directly to FLAC?Thanks
, then after that I encode to FLAC (in batch mode) .
Yeah, in the FLAC frontend just click "add files" and load up any number of wav files for encoding. Then simply pick the target folder ("output directory") and press "encode". They'll encode serially.My Foobar GUI is in my gallery (link below). All the albums are FLAC.Ted
