Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
FryKleaner Pro question...using to burn in phono section...
0 Members and 1 Guest are viewing this topic. Read 1234 times.
Steveparry
17 Aug 2005, 01:56 pm »
Should I disconnect the outputs that go to my line stage when I use this to burn in my phono preamp, or leave them connected, or turn the unit on (at low volume)? Does it matter?
Thanks, Steve
hagtech
Facilitator
ยป
17 Aug 2005, 05:59 pm »
You can do it either way. Having an input signal to the linestage will not cause any harm. If the unit is turned on, then it too, will get burned in. This is the easy way to burn everything in the chain.
jh
Other Stuff
Hagerman Technology
hagtech
