I need remote control for Foobar.....
0 Members and 1 Guest are viewing this topic. Read 3179 times.
Marbles
« on: 11 Aug 2005, 12:32 am »
OK, I have Empirical Audios Turbo Off Ramp m-audio card going to my Perp Tech dac.
It sounds pretty good.
It is inconvienent to get up and walk over to my computer to skip, pause, stop or even to pick the next CD.
Is there an easy and cheap way to add remote control to a PC?
It would have to work from about 25 feet away.
A wireless keyboard/mouse might work, but I don't know Foobars keyboard controls and the icons for the CD player are too small for me to work a wireless mouse from that distance.
Carlman
« Reply #1 on: 11 Aug 2005, 01:23 am »
I wish I had a good answer for you... but I tried really hard to find a solution like what you seek.... I ended up putting the monitor and keyboard (w/mouseball) next to me.
My next plan is to listen to a Squeezebox and compare it to my Audio PC.  If the sound quality is the same (or better), I'll get the box, which comes with a remote and then move the PC to the office and start adding tons of hard drives. ;)
I've thought about configuring and programming a custom user interface using a Palm device.... but that ended up being its own project that I'm not fully capable of doing...  However, it CAN be done... I just don't have the time and $ to invest in it.
There's no easy answer I could find... Good luck and hope someone here thought of something clever.
-Carl
ted_b
« Reply #2 on: 11 Aug 2005, 02:19 am »
Foobar's keyboard shortcuts, which can be easily customized, are listed in the preferences under "core > keyboard shortcuts".  A good wireless keyboard would work; or use a product like the ATI remote wonder ($49); or a product like Girder (http://www.promixis.com/) and most any pgmable remote.
Ted
Marbles
« Reply #3 on: 11 Aug 2005, 02:20 am »
:notworthy:  :notworthy:  :notworthy:  :rock:
Thank you!!!
Carlman
« Reply #4 on: 11 Aug 2005, 01:43 pm »
I knew there would be something clever out there...   Thanks, Ted!
JoshK
« Reply #6 on: 11 Aug 2005, 02:25 pm »
I think the airpanel is cool but I think a touch panel such as these AMX would be cooler from just a useability standpoint.  However I haven't read up on the software requirements but I know there are sites and forums about using them with a HTPC front end.
ted_b
« Reply #7 on: 11 Aug 2005, 02:28 pm »
VERY cool, but a bit pricey ($350-400) for a remote solution, unless you have a full-blown HTPC and all processing and audio/video goes there.
Marbles
« Reply #8 on: 11 Aug 2005, 02:41 pm »
Never mind, the Girder remote control looks fine, except the receiver is USB based.
I only have 2 USB ports on that computer and I that would be the 4th USB device  :x
Looks like I need to get a USB hub to add to my computer.
JoshK
« Reply #9 on: 11 Aug 2005, 02:43 pm »
Quote from: Marbles
Anyone know how to add extra USB's in an easy way?
Get a USB hub.  Search Newegg for solutions.  There are both internal and external usb hubs, they work similarly just different ergonomics.
Marbles
« Reply #10 on: 11 Aug 2005, 02:47 pm »
Thanks, I was editing as you were posting.
I spoke to my PC store owning friend and he recomends an external 4 port hub for about $20.
Sounds pretty easy in the scheme of things.
Brian T.
« Reply #11 on: 12 Aug 2005, 08:31 am »
Marbles,
You might want to take a look at Patrick Cazeles' site and see if you can use his PDA control module.  He is at: http://pcazeles.perso.cegetel.net/acxo.htm
Brian
Marbles
« Reply #12 on: 12 Aug 2005, 02:20 pm »
Quote from: Brian T.
Marbles,
Brian
I don't think I will use a PDA, but I have booked marked that page, as I intend to do digital room correction at some point.
Thanks for the link.
