LCR and 61 cabinet blow out
0 Members and 1 Guest are viewing this topic. Read 3143 times.
RAW
« on: 10 Aug 2005, 01:59 am »
We have CNC baffles for the LCR and the kit 61.
And have put a special price for the CNC baffles on our site.Clearance page. RAW Acoustics does not sell Exodus kits.
Kits can be ordered from DIY CABLE and we will be happy to supply the pre machine baffles and magnetic grills.
or
For those looking at cabinets.
-Kit 61 cabinet while supplies last with our CNC front and grill for $90.00 each including FREE SHIPPING to the US and Canada
-LCR cabinet while supplies last using our CNC front and grill for $160.00 each including FREE SHIPPING to the US and Canada
These prices only apply to those ordering kits from DIY Cable or CSS.
-Kit61 cabinet all 3/4" MDF
port hole cut in the rear
terminal cup hole cut or binding posts
-LCR 1" front 3/4"all other parts
Limited quantity on these pricing.
« Reply #1 on: 10 Aug 2005, 04:50 pm »
Al, do you have pics of the kit 61?
RAW
« Reply #2 on: 10 Aug 2005, 06:20 pm »
Look on the DIY cable site or the CSS site.
Sorry I guess this was not explained well enough in the above post.
 :wink:
Kevin P
    • http://www.diycable.com
Re: LCR and 61 cabinet blow out
« Reply #3 on: 10 Aug 2005, 10:30 pm »
Quote from: RAW
or
-LCR cabinet while supplies last using our CNC front and grill for $1 ...
Hey... don't leave out Kyle @ Acoustic Visions.   He deserves to be let in on the deal.   :)
RAW
« Reply #4 on: 10 Aug 2005, 11:53 pm »
:oops:
Sorry Kyle
bald
« Reply #5 on: 21 Aug 2005, 04:03 am »
Are any of the CNC LCR baffles of the front ported design that kyle posted?
bald
RAW
« Reply #6 on: 21 Aug 2005, 05:11 am »
[img]http://quicksitebuilder.cnet.com/wrnch2/sitebuildercontent/sitebuilderpictures/lcrfrontviewwgrill.jpg[/img
LCR CNC (pre machined baffle)
:: 1" MDF cabinet
:: driver holes cut flush mount if using 30mil veneer
:: Magnetic Grill included
     Baffles size 28" X 11.5"
Once stock is gone we are not replacing these baffles
Al Garay
« Reply #7 on: 22 Aug 2005, 03:29 am »
Al,
Your image did not get posted. Perhaps you can add it to the gallery?
RAW
« Reply #8 on: 22 Aug 2005, 03:43 am »
Lets try this again.
Front view and back view of the baffle and grill.
They are on the clearance page
Al Garay
« Reply #9 on: 22 Aug 2005, 06:01 am »
So, if I'm using 10 mill paperbacked veneer from tapeease, the drivers will be "proud"?
RAW
« Reply #10 on: 22 Aug 2005, 02:24 pm »
Al
As I said to Kevin the baffles we have made are for 30m veneer and if you use 10m yes the drivers will stick up proud.
We did this as if we were using 10m we could easy use a bit to flush mount them down to match 10m veneer.
Easy to cut down but you can not add material if they are cut to deep :lol:
And for $29.00 for the baffle and grill made from 1" MDF these are a deal.
Take the material cost and the time you lay out the driver locations alone that makes them worth it.
As of today we only have 10 LCR remaining after they are gone we are not making more.
