Your concern is very valid. Today in hifi the trend is toward smaller/cheaper cabinets, less sensitivity and higher thermal compression/distortion. According to TC sounds, this is the #2 contributor to motor distortion in cone units. I am sure many folks would agree that more sensitive drivers have a sense of dynamics not present with less sensitive speakers.
The recipe for a more sensitive speaker is simple. The bass driver and cabinet are the limiting factors for sensitivity. It's easy to find a sensitive tweeter, but not so easy/cheap to implement a sensitive woofer. All things else being equal (i.e. Bass extension and Q) every 3db in sensitivity will cause the cabinet size to double. Obviously the driver parameters must change, but the limiting factor is the cabinet SIZE. In this scenario for the 1801 obtain 87.5db/watt, the cabinet size must double. For it to obtain 90.5 ohms, it must again double. For it to obtain 93.5 ohms it must again double.
Before going further, I must explain that there is some "cheating" happening with regard to impedance ratings. This is unregulated and therfore unpunishable. Many manufacturer will list a "nominal" impedance of 8 ohms, but their speakers will really dip to 4 ohms. The word "nominal" is not regulated and not enforced. If any speaker lists 4 ohms anywere in the impedance rating, the 4 ohm impedance is in the woofer region where most of the juice will flow from your amplifier and where the cabinet size is effected.
Since speakers are generally rated a 2.83 volts, a 4 ohm speaker will produce 3db more spl than an 8 ohm speaker. This is simple math. IF you wish me to explain this, I can. The rating is gernally db/volt. If, however, the rating were db/watt, the spl produced would be the same between the 4 and 8 ohm speaker. As an aside, I believe the onset of 4 ohm speakers is bad for purist hifi. I can explain further if you like.
Okay, back on the subject...
To increase cabinet sensitivity, starting with the 1801 sensitivity, a speaker would have to grow thus:
22 liters - at 8 ohms 84.5db/2.83v // at 4 ohms 87.5db/2.83v
44 liters - at 8 ohms 87.5db/2.83v // at 4 ohms 90.5db/2.83v
88 liters - at 8 ohms 90.5db/2.83v // at 4 ohms 93.5db/2.83v
176 liters - at 8 ohms 93.5db/2.83v // at 4 ohms 96.5db/2.83v
It's easy to see how the cabinet will grow dramatically as the sensivitiy increases. Given the commercial cost of a big cabinet, these speakers are indeed very expensive.
Herein I will offer some personal subjective opinion. The Tannoy Churchill in that big whoppin' cabinet sounds very good. That big paper cone will flex, but there is relatively little thermal compression in that speaker. Given a SET amp, I believe the most appropriate speaker is a VERY big speaker with VERY high sensitivity.
There are many sources of distortion in modern loudspeaker drive units. There is motor linearitiy distortion, spider linearity distortion, cone flex, magnetic variation distortion (uneven gaps), cone flex, cone resonance, frame vibrations.... and thermal compression.
So... my recommendation is potentially twofold.
1. Buy a pair of big old Klipsch speakers, and update them with modern crossover components.
2. Danny Richie did this project a few years ago and the parts are still available
http://www.gr-research.com/discontinued/alpha.htm . The only question I would have about this project is why Danny Richie dumped it. I suggest you call Danny via telephone and as him this question. Danny is a good guy and will be very honest with you.
At present, there are NO DIY speakers at 90db+/8ohms with high quality stiff cones and low distortion motors (i.e. bigger 1801) for tradional single amplifiers. Eventually I may change this.
There are other issues regarding amplifiers too, but... I must go to work.
Dave
