0 Members and 1 Guest are viewing this topic. Read 6443 times.
Has anyone ever played with the "Symphony" from Olive?
It claims it's an audio device, but they aren't publishing audio specs? Hm. I'd look for some discussion of noise
and also some discussion of how it handles multichannel sources.
If you are talking about the quality of output signal (as in S/N ratios), I'm assuming that it sends out bit-perfect output over the digital coax or optical outputs, or perhaps even the USB port. I don't know this for a fact, however, and thus my questions.
QuoteIf you are talking about the quality of output signal (as in S/N ratios), I'm assuming that it sends out bit-perfect output over the digital coax or optical outputs, or perhaps even the USB port. I don't know this for a fact, however, and thus my questions.I assumed it had an audio output. If it's $900 for a fanless computer that doesn't output analog audio, you might want to look at Hush Technologies. They might be cheaper.
Very interesting option. It looks like they did the hard work for you already with configuration and build of a slim pc. I like the one touch record and archive feature, that is a slick point. I plan to use automation software to reach this end but it is nice that it is already done and preloading your CDs is a nice touch, although that isn't too many at FLAC on a 80GB HD. Does anyone know whether it will pull off external HDs? It would be a great front end if you could remove the HD and pull off a server. I'm assuming the removing the HD would be difficult though.
80GB is just not an acceptable size for an application like this (especially at its almost $1k price point). Even using lossless compression, there is a small number of cd's that can be stored on such a small drive. Seeing how cheap storage is today, I am not sure why the vendor doesn't offer larger capacity.To me, that is a showstopper.George
Actually Scott, any sort of slim client doing a boot off of a remote server would be up to task and the Roku Photobridge has be hacked for just this. You could of course build your own diskless slim client and if the guts of the processing were done on the server then the slim client wouldn't need much CPU power.
They are using a notebook disk, almost certainly, and a slow/small one at that, because that's the only way you can keep a disk quiet and cool. Disks click and whirrr. Over computer fan noise you don't notice, but in a fanless system, you will. Was that a quiet drum tap or a loud disk seek? Grrrr.I spent a whole lot of time looking at quiet PCs - and ended up not building one because the tech isn't there yet. What I dream of is a system that can run games - this takes major processing power and even mor ...
Have you looked at Zalman's fanless cases? They just released a new one, TNN 300, that looks like it performs pretty well Review. It's a full system for 1000 pounds and uses passive heatpipe cooling. A warning, the site is in the process of being slashdotted, so the response may be a bit slow.
I've got an admittedly simple system doing exactly as you suggest, and inclusive of the projector and hardware was WAY under US$10k.
Where do you live Scott that is THAT quiet in terms of ambient noise floor? I can only dream of such a thing in my 14th floor condominium!
A mere whisper is already in the order of 40-50 db, so IMHO a cabinet cutting sound by 30db ought to meet your requirements, especially if you can put it in the room just next to your listening area...
