Other Stuff
Archived Manufacturer Circles
ModWright Instruments (MWI)
Modwright 999ES arrived - a few questions
0 Members and 1 Guest are viewing this topic. Read 2395 times.
Chris_B
7 Aug 2005, 03:14 pm »
My 999ES arrived Saturday. I was lucky enough to get in on the special buy Dan advertised in June - one heck of a deal. Nice job on the packing Dan. The unit is incredibly well built, especially the outboard power supply which is built like a tank and quite heavy.
What steps should be followed when setting the player up? I assume the moded outputs (with the tubes) are the L/R stereo ones but this player has 2 of them. Are both of them us the moded output path?
I still need to go into the menus to turn off the video circuitry and the 5.1 outputs. I supposed that will help too.
Thanks much Dan. I look forward to putting this player through its paces.
Chris
ted_b
Volunteer
"we're all bozos on this bus" F.T.
7 Aug 2005, 03:22 pm »
There are a lot of tips and info on the earlier 999ES posts/threads. I own one of the first batch, and love it. The tubed output is either stereo output pair; the other is in the 5.1 section and is the l/r for the multichannel (not tubed, but possibly modded with some upgraded opamps if you had it done, as I did). Check out my posts and others regarding break-in time and process (200 hrs, pre doesn't need to be on) :
http://www.audiocircle.com/index.php?topic=16503
ENJOY!!
Ted
Chris_B
Reply #2 on:
7 Aug 2005, 04:29 pm »
Just so I know I got it right, both of the two outputs on the left are moded, correct? Sorry it's so out of focus.
ted_b
Volunteer
Reply #3 on:
7 Aug 2005, 05:42 pm »
Yeah, they're the same outputs, just duplicated, and are the ones going through the tubed section. I have mine in output set 1 (left most, as you have yours).
Ted
Chris_B
Reply #4 on:
7 Aug 2005, 08:34 pm »
Thanks. I'll give it a few weeks to run a few hundred hours through it and report back. I am sure it will be a great match with my SWL 9.0SE preamp.
take care,
Chris
ted_b
Volunteer
Reply #5 on:
7 Aug 2005, 09:33 pm »
Same marriage (pre) as mine...great results. You will love the sound.
Ted
Other Stuff
