0 Members and 1 Guest are viewing this topic. Read 7191 times.
John, That Mac Mini is working out I guess ? [/list:u]Chris[/list:u]
FWIW, I'm 100% HD based (with backups in CD, CD-R and/or HDs), except for customer demonstrations. I have 6000+ songs in Apple Lossless on my Firewire drive attached to a wireless Mac Mini feeding a Sherbourn 2/75 amp and a pair of NHT iC4 inceilings for work and 1500+ songs in AAC on my iBook (wirelessly feeding an Airport Express) and duplicated on my iPod for the house. And we just started selling Sonos instead of any kind of CD changer. Maybe no one's talking about it because we don't want to take the steely barbs of the "serious" audiophile crowd?
Ah.. this isn't what I call computer audio. At least, it's not at attempt to take the outputs of a standard soundcard into a stereo. I'm all for doing a lossless transfer of CDs to a hard disk (tucked in a closet somewhere) and then playing that though a decent DAC. That's a far cry from throwing a PC into a listening room and using the soundcard outputs for anything worthwhile. That's a non-starter.Given that everyone's got 100mb ethernet and rivers of bandwidth these days, I keep hoping we'll see lots ...
well Redhat Linux 9.0 is kicking my ass....can't get the damn NIC to install. I can see the damn driver but it says "no such device". 'Bout ready to throw in the towel and build the file server using Windows 2k. Maybe I need a more modern distro, maybe I'm daft? Anyway, when its up, i'll be stylin the SB2. Then I fully intend to open a thread in the lab about modding the SB2 opensource style. For those of use with a soldering iron and the nerve to use it, no sending the SB2 to someone else, its time to share info.
No this is a self built box, I have tried 2 different NICs, both 3com and D-link and neither RH9.0 would recognize. D-Link said to use the sk98lin.o but I couldn't get that to work. For 1) insmod is not recognized as a command, and the driver installation gave no further hints. It may be that I haven't installed the appropriate package but I'll be damned if I didn't try most everything.Re-reading your post, I might have misunderstood you. Not sure if this driver was for a dell box or otherwise. If ...
Assuming someone has a streaming solution such as a Roku or a SB2, does anything in the computer system itself effect the output? I cant see why it should, digital stream is a digital stream, but i have no experience with this application of it.
Scott,Which Roku do you plan to get? I have been thinking about the photobridge, with the current hacks it can be used as a HTPC frontend running off of a HTPC backend using myth. Except for DVD playback it may be the bomb for HTPC.
