What speaker wire you will get to do DIY speaker cable?
0 Members and 1 Guest are viewing this topic. Read 3187 times.
michaelv
Hi,
 Now, it's time for me to do DIY speaker cable.  My friend let me borrow the heat gun and crimp tool so that i can do DIY speaker cable. I would like to build two pair of single end or one pair of bi-wire speaker cable. First, this will be for testing of bi-wring Totem Forrest . Second, these sets will be used  in homethear speakers anyway.
  1>  Which speaker wire do you choose if you want to do DIY speaker cable?   So far i know only Carnare 4S11. Any other better cable than Canare?
  2> Do you crimp or solder cable?  I like to crimp , then solder. But which type of solder do you suggest? tools?
thanks.
SET Man
« Reply #1 on: 7 Aug 2005, 04:31 pm »
Hi,
    I'm currently using 26ga Vampire 6N long cystal magnet wire for all of my homemade IC with copper Bullet plugs, of which sound excellent.
   I planing to use 20ga version of the same wire for my 8ft run speaker wire. I still dont know what design I would use for speaker cable yet. Paralle run? Stuff in teflon tubing than twist pair? But I will be using 4 (=14ga) or more per connection. And will be using AudioQuest P8M silver spade, grind the wall inside to bare copper, crimp than solder.
    Well, hav fun and let us know how is turn out.
Goodluck,
Buddy :thumb:
jeffreybehr
« Reply #2 on: 7 Aug 2005, 06:05 pm »
Michael, I suggest you look at Homegrown Audio's stuff here http://www.homegrownaudio.com/silver_braid.htm .  I just made a 7' cable with their Silver Lace and it sounds slightly better than 2 versions of expensive AQ all-silver cable.
Also, I've read a few very-positive comments from others about this stuff.
Good luck.
andyr
« Reply #3 on: 8 Aug 2005, 10:24 pm »
Why don't you go search on Cable Asylum for the Jon Risch "Cross Connected" speaker cable recipe.  Alternatively, read this article:
http://www.aksaonline.com/discussion/discussion_papers_connect.html
It's great-sounding speaker cable, even if you just build the "standard" JR version.
Andy
michaelv
« Reply #4 on: 8 Aug 2005, 11:04 pm »
thanks all. I will .
michaelv
« Reply #5 on: 10 Aug 2005, 12:41 am »
By the way, what do you think of Cardas bulk speaker wire. So far i see only diycable.com carries it. Any place else?
SET Man
« Reply #6 on: 10 Aug 2005, 01:32 am »
Quote from: michaelv
Hi,
 Check out Percy Audio. Micheal Percy carry Cardas raw wire and other wire from other company and many Hi-End audio parts. I have been order parts from for a few years now. You have to download his catalog in PDF file.
http://www.percyaudio.com/
 The other place for parts Hi-End parts Welborne Labs. This is were I got my SET amp... don't forget to check out his DRD 300B :mrgreen:
http://www.welbornelabs.com/
Well, have fun let us know how your cable turn out.
Goodluck,
Buddy :thumb:
michaelv
« Reply #7 on: 10 Aug 2005, 01:40 pm »
I look at Cardas wire and it's expensive, about $3.5 / feet.  Another option is Audioquest (star quad like Canare).  Do you know if Audioquest is good?
thanks.
ScottMayo
« Reply #8 on: 10 Aug 2005, 05:54 pm »
I like milspec hookup wire - this stuff: http://source.as/pdfs/tyee.pdf . At 8ga, it's very stiff (which is sometimes awkward) but it's tough, doesn't change with time (or with heat, or acid, or smoke, or much of anything), looks big and impressive, and has the low resistance you want. The silver plating on the copper doesn't lower resistance all that much - any good 8ga copper already has very low resistance - but it does mean that the copper isn't going to tarnish with time, which is important, and the silver helps it "squish" nice and tight in a binding post.
I found some for $1.60/ft (keep in mind that's *1* conductor, not 2). I use it bare on speaker posts, making it the simplest and most elegant DIY effort possible: cut, strip, wrap, tighten, done. The lengths I use (runs of less than 12') have absolutely no discernable 'voice' whatsoever.
The military uses this stuff for higher voltage, higher frequency work than you will run into in *any* audio application.
rez
« Reply #9 on: 24 Aug 2005, 05:39 am »
Although selection is limited in some areas I like sonic crafts prices compared to some others http://www.soniccraft.com/index.htm
rez
