0 Members and 1 Guest are viewing this topic. Read 2565 times.
I also use a commercially available CD opener. While we were showing at 2005 T.H.E. Show, a rep with http://www.audioexcellenceaz.com came in our demo room and was handing these out - they had their web address marked on them, and used them like a business card (which I thought was a cool idea). It is a really clever but simple little device, which uses a small spring-loaded cutting blade which is automatically detracted as the gizmo is slid along the edges of a CD case. It actually works quite well. ...
Now if there was just an easy way to open a DVD. They put that security tape on all three sides and it takes forever to get off and you end up mangling the plastic cover in the process
