Need high sensitivity outdoor speaker recommendations
0 Members and 1 Guest are viewing this topic. Read 928 times.
tzonehunter
Hello All -
I'm looking for some high efficiency / sensitivity outdoor speakers. I bought a Sonic T-Amp that I had intended on using for my computer, but it didn't work out. So I'd like to try to use it for my patio instead. The problem is that it only puts out 15W X 2.
So can anyone recommend anything? I haven't settled on a rigid budget yet, but I'm thinking no more than $500 for the pair.
Oh, and one more thing. I'd like them to be as close to full range as possible.
T.I.A.
- CT
brj
« Reply #1 on: 6 Aug 2005, 06:13 pm »
Are you talking about fully exposed hidden-in-a-fake-rock type speakers, or something that will be partially protected from the elements by a patio roof or overhang?
How are you looking to mount them?
tzonehunter
« Reply #2 on: 6 Aug 2005, 06:24 pm »
I'm not looking for the 'in a rock' speakers.  They will be partially protected, most likely hung from a sophet.
