HT/audio component furniture
0 Members and 1 Guest are viewing this topic. Read 1010 times.
pugs
« on: 4 Aug 2005, 03:54 pm »
I'm looking for a component rack/TV stand similar to the Salamander synergy series like the tripple S20 with riser.  Are there any other options out there, preferably cheaper than the Salamander?
Bingenito
« Reply #1 on: 4 Aug 2005, 04:41 pm »
Nothing that comes to mind that is cheaper but I would recommend that you hold off on buying a rack until you know you are done changing gear around. Unless you buy a modular rack.
warnerwh
« Reply #2 on: 5 Aug 2005, 03:48 am »
It's easy to make a Salamander clone. The nice thing about it is that it's adjustable and you can use any finish of wood you like too.  It cost me less than 150 to build a double wide rack with four shelves, more than I really need.  Lots of discussion on this topic over at AA. You can email me if you want any help. I'm no woodworker and had no problem building one. Actually I thought I came up with the idea myself after seeing one but found it's a very common diy rack.
