Extending the FREE Quicksilver paste promo through Labor Day
0 Members and 1 Guest are viewing this topic. Read 1332 times.
Reference Audio Mods
    • http://www.referenceaudiomods.com
Introduction
Reference Audio Mods is proud to carry and install the exceptional Superclock 3 from Audiocom International. We are the authorized Audiocom International products distributor for the United States.
The SuperClock 3 is an aftermarket reference Ultra Low Noise, Ultra low-jitter clock, guarunteed to improve any CD/DVD/SACD player and transports performance dramatically!! The SuperClock3 is the single largest performance upgrade you can make for your system!! REDISCOVER YOUR MUSIC TODAY! You will now be able to visually see a COMPLETELY LARGER SOUNDSTAGE, just like you would see if you were in the recording studio or room watching your favorite group play. The emotion and life-like activity in the soundstage is now apparent and very startling, instead of a boring, bland 1-plane voice singing in front of you. This clock will make the timing, pace and rhythym of your player absolutely perfect. You will hear how incorrect your current players clocking system really is! Bass is very tight, full and refined, not lumpy or 1-note-ish. No Glare, No Grain, No Harshness!.
Why upgrade the Clocking Circuitry in your Digtal Source or DAC???
In more than 90 - 95% of CD players (SACD, DVD & DVD-A ) the master clock whose function is to generate a low jitter square wave. It is the "heart" of your CD/DVD/SACD player and a key vital role in reproducing accurate sounding music, like a live presentation. The stock jitter clock is a simple passive circuit which uses the input of an inverter, typically 74HCU04 and consists of a quartz crystal, 2x low value capacitors in series fixed to ground, and 1-2 resistors. The remaining 5 - 10% of players (usually higher priced units) are slightly better and use a clock oscillator module which uses its own inverter and has a better temperature stability, or use a single discrete transistor oscillator circuit. This is true of machines costing $500- to $20,000- regardless of manufacturer or model.
Even the very best players in the world cannot match the accuracy and low jitter performance of the SC3. None of these methods are suitable and all produce high losses of resolution (high jitter and error rates)for both audio and video recording and playback which closes down soundstaging, focus, detail, micro/macro dynamics and liveliness.
Does your CD/SACD/DVD player need more focus, detail and soundstage width? Do you wish to get more inner resolution and liveness in midrange and high frequency resolution? There is absolutely no reason to sell your Digital player or upgrade to the next model and the amount of performance difference will be slightly marginal. Adding the SuperClock 3 for starters is the largest performance you can make in your system.
You need the Superclock 3 in your player!! You are missing critical and vital information that will bring a very live presentation. The Superclock 3 completely fixes all these jitter and error related problems, leaving the user with a live breathtaking experience that some the most expensive players on the market cannot retrieve even with their own propeitary clocking systems!!
The Superclock 3 power supply is a great additon to provide extremely clean and fast power to the clock circuit. The typical clock circuit pulses 8-45 million times per second, this clock supply is much needed to maximum the performance over using the stock power supply in your player which is too slow and dirty and will round off the edges of the square wave of the clock signal. The Superclock 3 power supply is rather large and may not fit in all players. .
Audiocom SuperClock 3 $295 ea (Any typical Frequency available)
Built from many years of experience the new SC3 has reached a level that far surpasses any other aftermarket clock we have heard...and yes, even the Superclock 2! The SC3 has been completely redesigned using only state of the art components meticulously hand picked for there sound. RAM has directly compared the SC3 to the SC2 and the results are truly phenomenal! Improvements we hear: First and foremost is the incredible sense of presence. It is as if music is now "in the room" or NOT locked onto the speaker. There is now a complete lack of strain and compression which is now so very noticeable without the SC3. Macrodynamics are greatly improved over the SC2. The SC3 provides dynamics much closer to live music such as in the "pop" of a snare drum or the "pluck" of a bass guitar. Resolution. We simply hear more musical information. Inner detail and imaging are now very prominent. The musical presentation now sits on a much larger lifelike stage. Bass slam comes through with a sense of realism. We descibe the bass as sounding very "open" of lack of strain. Vocals are much cleaner and natural sounding, again providing that "in the room" sound. Uncanny! The High frequency information comes through with delicacy and tonal color. Bells in certain tracks were simply smeared with the SC2. Using the SC3 we hear absolute clarity,extension, and openess. .
Audiocom SuperClock 3 Power Supply Unit $295 ea
We also offer a dedicated power supply unit to power the new SuperClock 3. This makes a nice noticabel difference in the sound, offering more neutrality and resolution in the soundstage. (If Reference Audio Mods installs this for you we modify the power supply further for even better sound!)
How Much? Where to Buy? Where to send unit for Free install?
The Audiocom Superclock 3 and PSU units are $295 ea. (w/free installation) and can be purchased on our website (follow the link below). (return shipping is extra, typically a $20 flat rate for most players, please inquire). Installation is done by RAM East.
FLASH!- RAM Special!! Get a FREE Xtreme AV Quicksilver Silver Contact kit FREE with every order placed for SC3 install from this Ad in through Labor Day! $64.95 value FREE!
  • Click here to instantly go to the RAM Superclock 3 info and ordering page!
    While your unit is at RAM EAST, please consider some of the other high performance options listed below. Musical performance that will exceed your expectations!!! we guarantee it!!
    Reference Audio Mods can not only install the SC3 but take your player even further with a whole list of potential modifications possibilites. Through constant research, as well as trial and error, RAM strongly believes our parts and philosophies are the finest available in the world:
  • Rubycon ZA/ZL capacitors: Incredible sounding capacitors that offer extremely low impedance and high ripple current. Really another level over the Blackgate capacitors!!!
  • Exotic Ultra High Speed RAM diodes bridges made out of silver
  • Audiocom Invisus Voltage Regulation. A fantastic discrete regulator that outperforms any monolithic 3-pin type. The fastest sounding regulator we have heard, brings more speed and life into the sound!
  • Superb Jensen 4-Pole Capacitors for Power Supply smoothing. The very best large value caps we have heard to date. These sweet 4-pole caps offer lifelike tonality and great transient speed.
  • Transformer Coupled Output stage.It's easy "Simpler is better!" RAM uses a very simple approach to the output stage: keep it simple as possible but never simpler and use the best possible parts for this application. We use the Audio Consulting copper or silver coupling transformers to direct connect the dac chip or I/V converter to RCA's! Simple and direct for best sound. No power supply distortion issues, all pure passive approach!
  • Audio Consulting Power supply transformers for unsurpassed Energy Transfer and the highest level of resolution/dynamics possible
  • WBT NextGen (Eddy Current Free Design) RCA female jacks for an unbelievable thrilling sonic experience.
  • -and many many more!!!
  • Please check out our website at
    www.referenceaudiomods.com We offer Discussion Forums to ask questions and learn about our high performance mods and products.
    Please click here to enter the Reference Audio Mods Discussion Forums!!
    INSTALLATION SERVICES & INQUIRIES
    Contact Doug Jesse at RAM East at [email protected] or feel free to call us at 1-586-944-5611.
    If you are in california or extreme west coast, please call Kyle at 951-780-2869 for installation inquirys.
    PART ORDERS & INQUIRIES
    Contact Kyle Takenaga at RAM at [email protected] or feel free to call us at 1-951-780-2869
    Please check out some of our popular mods we perform to these very popular machines that utilize the Superclock 3:
  • Denon 2910 Mods!
  • Denon 2900 and 3910 "Reference 1" Mods!
  • Marantz SA-8260 Mods!
  • Toshiba 4960 and Samsung HD-841 mods and new modded players!
  • Esoteric DV50 "Reference 1" Mods!
  • Bel Canto DAC2 Mods!
  • New! Sony SCD-1/SCD-777ES "Phantom" Mods!
  • Please click here to enter the Reference Audio Mods Discussion Forums!!
    We can develop a custom mod package based on your player just like the models shown above.
    Thanks and we look forward to assisting you in the path of the best sound available today!
