A Toroidal Transformer in lew of the Hammond 370BX
0 Members and 1 Guest are viewing this topic. Read 2891 times.
LFE
Can anyone out there suggest a Toroidal Transformer (or Multiple) that could replace the Hammond 370BX?
LFE
« Reply #1 on: 2 Aug 2005, 07:18 pm »
This is for the Clarinet Pre amp.
JoshK
« Reply #2 on: 2 Aug 2005, 07:46 pm »
Why would you want to replace a good EI core with a toroid?
LFE
« Reply #3 on: 2 Aug 2005, 08:33 pm »
Height of the supply. I want to put the supply in the case, not mount it on top.
JoshK
« Reply #4 on: 2 Aug 2005, 09:04 pm »
check out www.vt4c.com and look at their R-cores, a much better solution I feel.  Toroids aren't a great solution because they have a widebandwidth meaning they pass the crap along with the 60hz wave. Also w/o a interwinding shield they have high capactive coupling.  R-core is better than a toroid in these regards and are lower profile which is why they are used in a lot of the better CD players, like my Sony XA777es.
Then you could always put the Hammond in an outboard enclosure like I did and use 8 wire pro cables along with a 8 pole speakon connector set and place the transformer outside of the case which will also lower noise.
LFE
« Reply #5 on: 2 Aug 2005, 10:14 pm »
Do you have a picture of the outboard hammond set-up?
