Stratos Extreme Demise
0 Members and 1 Guest are viewing this topic. Read 2032 times.
KarlDL
« on: 2 Aug 2005, 03:22 am »
It had to happen.  The new plasma HDTV arrived this morning.  Upon programming and configuring it, my son discovered that my right channel audio was dead, on all sources.  Further investigation when I got home revealed that the right channel Stratos Extreme died.  Fuses blown.  Only one pair of output transistors intact, remaining 6 appear shorted.  It worked just fine on Saturday - no idea what happened!  Hey, it's the younger of the pair, so it needs to catch up to its sequentially upgraded "brother" on return visits to Indy!
djbnh
« Reply #1 on: 2 Aug 2005, 11:13 am »
Man, that's a very sad "short" story.
bunky
« Reply #2 on: 2 Aug 2005, 11:24 pm »
hey karl, i am sorry to hear about your misfortune but in a way it is a good thing. now you can get a matching red board unit and improve the overall sonics of your system.              sincerly william c waldecker 3rd
KarlDL
« Reply #3 on: 3 Aug 2005, 03:06 am »
Actually, both amps were "SOTA" as of last summer.  The demised one was the "all new" unit, the survivor the "veteran", but with red board installed at the same time as the new one was built.
Further interrogation of my son revealed that the amp died early into Spiderman (I) on DVD, not prior to plasma activation.  Even more mysterious, that DVD won't load now on the DVD player.
Anyway, what's somewhat troubling is that the Stratos' internal protection circuitry was not able to prevent catastrophic transistor failure.  While those of us with a few years in electronics know that "the transistor protects the fuse by blowing first", the amp is designed to prevent (blatant) suicide attempts.
So the exact sequence of failure events remains mysterious.  Did the cleaning ladies short the outputs by shifting the amp?  Was there some kind of tranient glitch in the DVD that excited a heretofore unknown weakness in the protection scheme?  Or is this a case of one-year-old transistor mortality arising from a bad silicon batch?  Only the Shadow knows ...
bunky
« Reply #4 on: 3 Aug 2005, 08:09 pm »
the good thing about dealing with odyssey i.e klaus bunge is that you know he will get your amplifier squared away. the failure you describe is most likely a fluke. after all nothing in this world is perfect.i know of no other audio manufacturer that stands behind thier equipment or has the high degree of customer service that odyssey has. when i call or need something i only deal directly with the owner of the company and he has never let me down.
