PMC OB1
0 Members and 1 Guest are viewing this topic. Read 4510 times.
dick thoreau
PMC OB1
« on: 28 Jul 2005, 09:35 pm »
I am interested in opinions about the PMC OB1 speakers.  I have a listening room roughly 13x17x8ft.  I listen to mainly large orchestral music and some classic rock.  I have heard the IB1's at a dealer but not yet the OB1's.  I realize that the IB1's are better speakers (more costly as well) than the OB1's. However  I was wondering if ,in my size of listening room, that the OB1 could really fill up the room with sound.  I likely will not be able to demo these at home so would appreciate any comparisons of the 2 speakers.  I am looking for something that can really fill the room with a big soundstage and play both hard rock and orchestral music. I like the IB1's ,BTW, but hoping to get a similar sound in a slightly smaller and cheaper package. Any thoughts and comparisons would be helpful.
thanks
jethro
PMC OB1
« Reply #1 on: 29 Jul 2005, 12:35 am »
dick,
You'll probably agree that the IB-1 will fill your listening room. I have a 13.5' x 18.5 ' room with IB-1's for LCR.  The OB-1 has the same HF and MF drivers as the IB-1's so the remaining issue is the bass driver (aside from any crossover and enclosure differences). I haven't heard the OB1's, but I assme one of the reasons for the IB-1's higher price is the 10" flat driver. I believe the FB-1+ has a similar bass driver to the OB-1. Can you get a demo of the FB-1+ at home to determine if the OB-1  bass meets your needs?
dan_lo
PMC OB1
« Reply #2 on: 29 Jul 2005, 08:01 am »
The OB1 can easily fill your listening room. It does not use the same bass driver as the FB1 (Vifa). It has the same driver as the TLE1 subwoofer (Dynaudio).
I heard these speakers in a room similar in dimensions to yours and it had no problem.
  • The Demo is Everything!
    • http://www.bryston.com
PMC OB1
« Reply #3 on: 29 Jul 2005, 11:50 am »
The OB1 does use the same woofer as the FB-1 and it is a Vifa. The TLE as well.
james
dick thoreau
OB1 sound
« Reply #4 on: 29 Jul 2005, 06:15 pm »
I guess what I am looking for in the OB1 is a medium sized, full range speaker, which works well in mid to small size rooms.   Also, it has a relatively neutral tonal character,and can playback equally well most types of music. The main concern I might  have is whether it's bass performance is sufficient.  If it  sounds clean and defined down to about 30 hz and can sustain the bass for a bit without noticeable strain but need not give the home theatre chest pounding type of bass.  This would be ideal for my needs.  Judging by all the reviews I have read the OB1 should be ideal for my listening room.  However maybe I am expecting too much from a speaker of this size. I will eventually demo it (in the store only) but welcome any further thoughts or comments on it.
Thanks in advance
afblaster
PMC OB1
« Reply #5 on: 31 Jul 2005, 08:17 am »
There's much discussion on OB1s and IB1/2s in these threads  -
http://www.audiocircle.com/index.php?topic=15827&highlight=
http://www.audiocircle.com/index.php?topic=17728&highlight=
Bearing in mind the type of music you intend listening to, you may ultimately regret buying OB1s, but I wager you will have no second thoughts with IB1s.  When I purchased mine my dealer said they would be the last pair of speakers I'd ever buy, and he's right!
Crustyloafer
PMC OB1
« Reply #6 on: 20 Feb 2006, 09:47 pm »
Quote from: James Tanner
james
Can I ask then why they look quite different in the pictures.
The bass driver on the OB1 looks like a Dynaudio driver, and also looks similar to the onces used on the TLE1, which is is what 'dan_lo' seems to be saying.
PMC OB1
« Reply #7 on: 20 Feb 2006, 10:09 pm »
Same woofer - different dust-cap
james
Crustyloafer
PMC OB1
« Reply #8 on: 20 Feb 2006, 10:12 pm »
Thank you for your repsonse. very interesting and not what I expected. Is there a reason for the different dustcap? is it because they are being used for different frequency ranges in the different speakers.
PMC OB1
« Reply #9 on: 20 Feb 2006, 10:17 pm »
Not sure on that one.
james
Crustyloafer
PMC OB1
« Reply #10 on: 20 Feb 2006, 10:19 pm »
Can you find out for me? Or I can call Tom in the morning.
PMC OB1
« Reply #11 on: 20 Feb 2006, 10:22 pm »
Yes please call Tom and let me know as well.
By the way say - "HI TOM" from me.
james
Crustyloafer
PMC OB1
« Reply #12 on: 20 Feb 2006, 10:30 pm »
I will do James. I'm sure he'll be glad to know you are getting on well.
I don't suppose there is any chance that you could look into my own post requesting copies of past reviews of the OB1s.
http://www.audiocircle.com/index.php?topic=25845
PMC OB1
« Reply #13 on: 20 Feb 2006, 10:33 pm »
