0 Members and 1 Guest are viewing this topic. Read 4511 times.
I'm about to convert an office that is separated from my house by a terrace into a combination Office/HT/Listening room. I plan to dismantle the current almost nothing walls to start from scratch using only the existing roof and 4 corner support columns. With the equipment and drivers I already have, I have the capacity for extreme output all the way down to the low teens. I also watch a lot of movies late at night, so I don't want to wake the kids or disturb the neighbors...
You may be right about styrofoam. I was under the impression that it was very effective in a layered construction so it's high resonant frequency resulting from being rigid and lightweight could be damped. Maybe I should swap it out for 2 extra layers of chipboard and foam rubber for about the same price ...
this is purely intuitive but how would it be filling a wallspace between say an inner and outer layer of ply, with sand?jules
Thanks Scott,On the other hand, I don't think it's unrealistic to dissipate this relatively small amount of actual energy within a layered wall. I'm starting to think that airspace (or fiberglass insulation if I can find it) between each layer, ...
