How to battery power a DAC1?
0 Members and 1 Guest are viewing this topic. Read 1293 times.
gevorg
« on: 23 Jul 2005, 07:44 pm »
Hi all,
I'm using a Benchmark DAC1 in my stereo rig, and instead of investing in power conditioning/cords, I wondering if its possible to use batteries to power DAC1. Since its a source component, it will take much less power than a receiver/amplifier.  Are there anything audiophile-grade that can be used like this? I'm looking to spend well under $500.
Thank you.
sethk
« Reply #1 on: 29 Jul 2005, 04:16 pm »
The DAC-1 has a built in AC transformer, which would be something you'd want to bypass, unless you feel like using a DC->AC->DC path, which would probably be inefficient.
Also, the DAC-1 runs pretty warm in idle mode, in fact it seems just as warm as when powering headphones. I wonder if it runs biased in Class A.
Remember, it's not just a DAC, its got an amp section. It won't be as efficient as the DACs that are designed to run on battery power.
Jon L
« Reply #2 on: 29 Jul 2005, 06:32 pm »
Whatever you do, make sure it's reversible.  Many seem to prefer that liquid, self-effacing character of battery power, but it depends on your tastes.  So far, with equipment I've tried powering with SLA battery+caps, I prefer AC power from a good power conditioner for more spice, apparent detail, and Razztazz..
