Is the Motorola DVDeceiver the ugliest Tripath amp yet?
0 Members and 1 Guest are viewing this topic. Read 2501 times.
albee
Check this thing out:  100W/channel, Tripath powered.
http://www.overstock.com/cgi-bin/d2.cgi?page=proframe&prod_id=1535932#
TheChairGuy
« Reply #1 on: 22 Jul 2005, 02:19 am »
It's a good deal tho with CD/DCD, too, and 100 tripath amps for $169.00.
jswallac
« Reply #2 on: 22 Jul 2005, 04:23 am »
This is an older discontinued product that never really made it.  Not only is it a 5.1 amp and DVD player, it also replaces your cable box!  It was meant to be the ultimate plug and play one box solution from your friendly cable company.  I do not think it even had component out for video, S video was the best it did.
Bemopti123
« Reply #3 on: 22 Jul 2005, 05:23 am »
Man, that thing looks like a cross between an HK HT receiver and the worst imagination of a drunken industrial designer, lost in some David Lynch like movie setting.  Plain horrible, would make a pitbull run away with its looks.
Rob Babcock
« Reply #4 on: 22 Jul 2005, 05:32 am »
Probably it'd work pretty good in my bedroom.  I could ditch my crappy old VCR (it eats tapes, but I use it as a stereo tv tuner) and hook up my PSOne & Xbox to it.
TheChairGuy
« Reply #5 on: 22 Jul 2005, 07:01 pm »
Rob, everyone...this item seems to be widely available in the market, new and used, at significant discounts.
I looked over at Amazon and this product seems to have quality issues (new) and some problems that can't be remedied by re-manufacturing.
A couple reviews on Amazon:
High percentage of failures, February 17, 2005
Reviewer:    S. Smith (Telluride, Colorado) - See all my reviews
We bought these for our lodge (63 2 & 3 Bdrm Units). While the combination of components in a small package is exactly what we needed, we have experienced a large amount of product failures. Out of 67 units ordered, we have experienced a 30 to 40% failure rate. Types of problems in order of occurrence:
1) Audio section - a) Subwoofer worked, but not satellite speakers b) "Overload" becomes too sensitive
2) Digital cable subsystem failures - a) Constantly losing the digital programming b) or just complete failure
3) Premature DVD Read problems - I say "premature" because the oldest unit is less than 2 years old.
4) Front panel lockout.
While we are a "lodge", this is a private residence club whose members tend to take good care of the appliances in each unit. So abuse is not a major cause of problems. Also, the manufacturing dates range over several months.
A failure of 10% or less would have been acceptable, but close to 40% is just ridiculous. These units were professionally installed and we have worked closely with the local cable company to try and find an outside cause, without success. The surround speaker system used with the DCP501 is a high end Yamaha setup, while brand new Panasonic flat-screen TV's were connected using S-Video.
We do have other Motorola Digital cable boxes in use here, and none of them have displayed any of these issues. So we were very surprised to experience all these problems. It's too bad, because now we will have to look for a multi-component type of setup that we really don't have the room for.
Lots of features in a small package, but ..., May 18, 2004
Reviewer:    Christopher Jacoby "skylark888" (Chandler, AZ) - See all my reviews
I bought this device mostly on the Motorola name and the incredible discount. Overall, I am happy with this device. It sounds good, looks good, and I haven't had a problem with it yet. My biggest gripe is that the front panel display is quite difficult to read from even a few feet away, especially during the day. If the display were larger and brighter I would be much happier with this device. This problem could have been mitigated with more "on-screen" info coming through the TV, but the DCP puts very little info on-screen. For example, when changing TV channels I would like to see the channel number displayed on the TV, but the DCP501 doesn't do that. It will tell me the volume, but not the channel- it's a little odd that way. Dolby digital works as it should. I don't need the MP3 feature but it is nice to have. Not Earth-shattering audio power, but good considering that it's integrated. In short, I got a nice AM/FM tuner, CD/DVD player, home theater system, for a great price. I think this M S R P'd for a little under nine hundred, but I got it for about two fifty.
albee
« Reply #6 on: 24 Jul 2005, 12:22 am »
Great post ChairGuy, you just saved some unnecessary wailing and gnashing.
