0 Members and 1 Guest are viewing this topic. Read 22465 times.
The electrical conductivityof Aluminum is basically best case 62% that of Cu. Almost 40% worse.
No vendors of Cu/Al alloy magnet wire could be found via internet search.
Cable theory 101,.....The net practical effect from an audio standpoint of uncompensated inductance is the loss of Dynamics and Bass and High frequency response compared to a cable in which the inductance present has been accounted for by a geometery which by virtue of conductor spacing adds a necessary component of capcitance to the equation. Recall a series inductor is used to keep high frequencies out of a woofer......
Making twisted pair out of the 12Ga. magnet wire may yield better results than just laying them on the floor, a star quad geometry may be even better still but it will also be very stiff.
This would be a complex calculation. The site he posted shows a cable system as being a series of lumped inductors in series and capacitors in parallel. Some people suggest that such inductors and capacitors vary with frequency. The easiest thing to do would be to take a particular cable and measure its inductance, capacitance, and resistance at certain frequencies. Then you would have the equivalent of an RLC circuit and could estimate what a filter using those values would do. I'd probably take me all weekend or even longer to figure out how to get that far.
A question for ScottMayo. What is the rate of twist on your 8Ga. cables and why did you decide on this wire gauge with its particular mix of stranding, silverplated copper and teflon insulation.
beatdownvictim,the magnet wire, flat or round is already insulated.All you have to do is strip the insulation and terminate the flat wire with a spade or other connector or your choice. Scotty
truant since anticables only makes s/c's, what do you use for i/c's? i have used jps i/c's and s/c's the last 5-6 years. don't really like to mix brands
