0 Members and 1 Guest are viewing this topic. Read 22493 times.
It's a little different red (more of a true red) vs. the 13ga more burgundy red...so maybe all the wire gauges are color coded after all. Whatever....maybe ...
Hey Scott, Thanks for the interesting technical (and highly digestible ) tidbits.....I had no idea that magnet wire was partly aluminum. I suppose that means, among other parameters, greater conductivity isn't the only thing to focus in on (given that so many seem pleased with the Anti-Cables these days).
Silver plated milspec, 8 ga. Not too pricey, made to handle an absurdly wide range of frequencies under any conditions at extreme voltages, corrosion proof, sturdy and toddler and puppy resistant. Bare the ends, screw it in tight (retighten it the next day - copper compresses) and never fret again.
Quote from: ScottMayoSilver plated milspec, 8 ga. Not too pricey, made to handle an absurdly wide range of frequencies under any conditions at extreme voltages, corrosion proof, sturdy and toddler and puppy resistant. Bare the ends, screw it in tight (retighten it the next day - copper compresses) and never fret again.Heck, I'll give that a shot, too, if it's cheap. If I forget to put my 'Depends' on, I leak a little Do you remember where you got it and is anymore left for moi
Cable manufacturers by design have to go for the greatest common denominator, but are you like the GSD?
Quote from: ScottMayoSilver plated milspec, 8 ga. Not too pricey, made to handle an absurdly wide range of frequencies under any conditions at extreme voltages, corrosion proof, sturdy and toddler and puppy resistant. Bare the ends, screw it in tight (retighten it the next day - copper compresses) and never fret again.Heck, I'll give that a shot, too, if it's cheap. ... Do you remember where you got it and is anymore left for moi
