AKSA with 4ohm load
0 Members and 1 Guest are viewing this topic. Read 2513 times.
George W
AKSA with 4ohm load
« on: 10 Apr 2003, 07:54 am »
Hey guys,
This summer I plan on building North Creek Music Rhythm/revelator speakers and I was considering building an ASKA 55 (with nirvana upgrade) to power them.  The Rhythms are 4ohm speakers and the designer, George Short, recommends using an amp that doubles power into 4 ohms.  Just curious if the ASKAs provide this and if you feel they'd be a good match.  The Rhythms are slightly sensitive at 91dB so I'm hoping that's enough power.  Thanks,
George
AKSA
AKSA with 4ohm load
« Reply #1 on: 10 Apr 2003, 09:06 am »
George,
If the impedance of these speakers never drops below 3.5R, then all is well for the Nirvana 55W.  If it does, then I'd suggest the 100W Nirvana.
Either way, 91dB/watt/meter is just fine and the 55W will still go VERY loud.
Hugh
George W
AKSA with 4ohm load
« Reply #2 on: 10 Apr 2003, 11:00 am »
Thanks Hugh, I will verify the minimum impedance.
George
George W
ugh
« Reply #3 on: 10 Apr 2003, 11:08 am »
Hmmm 3.2 Ohm minimum....there goes some more money!!
Oh well guess I'll just be saving for awhile longer, ultimately we all know I would have wanted 100 watts anyway.  :wink:
I assume this will be fine with the 100w Nirvana?
Thanks for the help,
George
peranders
AKSA with 4ohm load
« Reply #4 on: 10 Apr 2003, 11:20 am »
Quote from: AKSA
George,
...and the 100 W plays only 3 dB louder......
AKSA
AKSA with 4ohm load
« Reply #5 on: 10 Apr 2003, 11:42 am »
George,
I am sorry.  But just to confirm, I have run the 55W with 3.5R speakers and it runs well, but when compared to the 100W amp there are occasional signs of strain;  it just doesn't have the drive.  With a 6R-8R load, it's actually very difficult to tell the difference between the amps;  but as you go lower, the differences start to emerge.  There is no doubt that with sub 4R the 100W is more suited as current delivery is superior.
Hugh
George W
AKSA with 4ohm load
« Reply #6 on: 10 Apr 2003, 12:26 pm »
Ok, 100watts it is.
Thanks Hugh,
George
PSP
AKSA with 4ohm load
« Reply #7 on: 10 Apr 2003, 02:21 pm »
Hi Hugh,
I've been considering building the GR-Research Diluceo (the MTM version of their new Criterion speaker).  It is a 4R speaker and dips to 3.4R; efficiency is around 91db.
I wrote to Danny Richie asking about biamping this speaker (it will work, since the Diluceo uses a parallel crossover)... the question to Danny was "what impedances would the tweeter and woofer amps see?"  Answer:  Highs 5-5.5R, dip to 4.5R minimum; Lows will see an average impedance of a little over 4R with a minimum dip of 3.5R at about 200Hz.
So, the question:  if I biamp these with 55w AKSAs, do you think I will be happy?  (Recall that I have 3 55w AKSAs in my house at present, so if I buy a 100w AKSA I'll have to postpone buying the GK-2, an option that is not in the cards.)
thanks,
Peter
