Phono stage upgrade
0 Members and 1 Guest are viewing this topic. Read 1458 times.
rmihai0
Phono stage upgrade
« on: 11 Jul 2005, 02:29 pm »
It is the tine to upgrade my phono stage. For the first year of comeback in vinyl I used a heavy modded NAD 1130. For its price ($200) it is superb. Now, I would like to try something else.
My budget is $600 (including the power supply).
My cartridge is an Ortofon Super OM40 (MM).
What is in your opinion the best (used) phonostage under $600 for Moving magnet?
Thank you for your help.
rotcoddam
Phono stage upgrade
« Reply #1 on: 11 Jul 2005, 02:37 pm »
The Cornet2 by Hagerman. Excellent sounding pre. But you need to put it together as it is a kit. Assembled its around $1000. The kit can be done for under $300.
