Squeezebox SB2 -> Off Ramp Upgrade?
0 Members and 1 Guest are viewing this topic. Read 5962 times.
barkerpj
  • PC -> Berkeley USB -> Berkeley DAC
« on: 11 Jul 2005, 01:04 pm »
I'm thinking of upgrading from my SB2 to an Off Ramp and wondered if anyone else had done any comparisons between the two.
There is a big price difference so I'd hope the Off ramp was a big improvement.
thanks in advance for any answers.
oris98
« Reply #1 on: 13 Sep 2005, 09:25 pm »
Hi all,
I am also interested to know the differences between the two. Any one has compared them ?
Thanks.
audioengr
« Reply #2 on: 14 Sep 2005, 05:37 am »
Peter Shand recently paid me a visit at BBR and brought his SB2.  We compared it to the Off-Ramp Turbo and the Off-Ramp I2S (prototype).  It was not bad from the S/PDIF output driving a modded P-3A, but the Off-ramps were both better.  They will do 24/96 and the SB2 wont.  I forget his moniker.
I imagine that the SB2 can be as good as the Off-Ramp at 44.1 with mods and a Superclock3.  The two crystals that I saw in there were not familiar frequencies though, and the wireless board is epoxied to the main board at the connector. May be difficult to mod the way I want to.  I may try one after the RMAF.  So many projects...my Off-Ramp I2S is a first priority.  I have customers with deposits on this one and it's not even a product yet.
Steve N.
Jon L
« Reply #3 on: 14 Sep 2005, 08:00 am »
Quote from: audioengr
I imagine that the SB2 can be as good as the Off-Ramp at 44.1 with mods and a Superclock3.  The two crystals that I saw in there were not familiar frequencies though, and the wireless board is epoxied to the mai ...
Steve, will the Off-Ramp I2S require that the outboard DAC also get modded by you to accept I2S cable?
audioengr
« Reply #4 on: 14 Sep 2005, 05:26 pm »
Quote from: Jon L
Yes, the P-3A must get mods to perform optimally with the I2S Off-Ramp.  It will still work without mods, but not nearly as good.  Other DAC's must have more extensive changes to accept I2S.  The P-3A will also require a special I2S cable that I make.
Steve N.
oris98
« Reply #5 on: 14 Sep 2005, 07:58 pm »
Steve,
Will the Benchmark CD1 be able to mod for accepting I2s too ?   I though at one point, you were thinking of modding the CD1 to accept USB directly..  Is it still in your plan ?
Thanks.
jman66
« Reply #6 on: 16 Sep 2005, 03:35 pm »
Steve,
Any timeline on when the I2S Off-Ramp will be available and at what
price? Would it hold true that ANY dac which has an I2S input could be
"fed" by the I2S Off-Ramp?
audioengr
« Reply #7 on: 16 Sep 2005, 09:01 pm »
Quote from: oris98
Steve,
Thanks.
I believe I can mod the Benchmark to replace the other inputs with I2S.
If I were to mod the CD1 to add I2S, it would probably eliminate it's use as any thing else.
Steve N.
audioengr
« Reply #8 on: 16 Sep 2005, 09:02 pm »
Quote from: jman66
Steve,
I need to design and fabricate a circuit board and then debug it after the RMAF.  This will take a month or two.
Any DAC with I2S should work with it, assuming that it is the same I2S.  There can be variants.
Steve N.
Ronm1
« Reply #9 on: 16 Sep 2005, 11:31 pm »
Quote from: Jon L
Yes, the P-3A must get mods to perform optimally with the I2S Off-Ramp.  It will still work without mods, but not nearly as good.    The P-3A will also require a special I2S cable that I make.
Steve N.
  You have my curiosity raised...
  Are the P3a mods diff than your existing P3 mods?
  Is this cable diff than what Brad already makes?
  I looked on the site but couldn't any info on the above!
audioengr
« Reply #10 on: 17 Sep 2005, 01:34 am »
Quote from: Ronm1
Quote from: Jon L
Steve N.
Yes, these mods are new, just for the I2S.  The I2S cable is my own design.
Steve N.
jman66
« Reply #11 on: 19 Sep 2005, 01:24 pm »
Perhaps I'm missing the "big picture" but what benefit is the 24/96 capability now that the Secret Rabbit Code binaries are no longer available?
Marbles
« Reply #12 on: 19 Sep 2005, 01:56 pm »
Foobar 2000 has it's own 24/96 upsampler that's not too bad.....
audioengr
« Reply #13 on: 19 Sep 2005, 05:28 pm »
Quote from: jman66
Marbles is right, the SSRC resampler is pretty good as well.  However, I am working with Erik in Australia to make the Secret Rabbit Code available to my customers, so it may be available again.
Steve N.
Marbles
« Reply #14 on: 19 Sep 2005, 08:39 pm »
my Off-Ramp I2S is a first priority. I have customers with deposits on this one and it's not even a product yet.  ...
 :mrgreen:   :wink:   8)
