0 Members and 1 Guest are viewing this topic. Read 3932 times.
It's not clear if by "soundproof" you mean you want to reduce sound transmission. ...
I was thinking about tearing out the drywall in my audio room so I can fill the empty space between walls with something to absorb sound. Would fiberglass insulation help with soundproofing or are there better options? And, should I put drywall back up afterwards or replace the drywall with something else? I also plan on applying acoustic treatments afterward -- is there something I could do while the drywall is off to help with that? Or should I simply apply the treatments to the bare studs?Thanks for your advice. -Rob
I guess I should qualify what I said a little bit as doing doubles on the outside may not be feasible.
Going back to Ethan's comment about sheet rock beign the cheapest and most effective mass -- I really hate working with the stuff ...
