How to cut fiberglass OC 703 2"?
0 Members and 1 Guest are viewing this topic. Read 4818 times.
michaelv
« on: 8 Jul 2005, 05:28 pm »
Hi,
 How do you cut the OC 703 , 2"? Since the outer frame is 2'x4', then the inner frame is less. Therefore i have to cut 1" for both lengths to fit inner frame. Which tool do you use?
thanks.
Ethan Winer
  • Audio expert
Re: How to cut fiberglass OC 703 2"?
« Reply #1 on: 8 Jul 2005, 06:02 pm »
Michael,
I've cut rigid fiberglass using a longblade razor knife and straightedge, but a table saw is better. Even a band saw is better than a knife, assuming the saw has a suitable guide / fence (or whatever it's called).
--Ethan
Kevin P
    • http://www.diycable.com
« Reply #2 on: 8 Jul 2005, 06:50 pm »
The table saw really works well.   It allows you to sculpt the sides for cool looking panels.
michaelv
« Reply #3 on: 8 Jul 2005, 07:36 pm »
Thanks to all. Since table saw is expensive and i only use once,  i guess i will build bigger outer frame to accomodate the inner size  frame  = 2'x4'
One more thing. The front of panel will be covered by burlap. Can i use regular fabric to cover the back, just to prevent fiberglass particles escaping into the air.  And i will place panel 1" away from the wall (the maximum i can do)
Ethan Winer
  • Audio expert
« Reply #4 on: 8 Jul 2005, 08:29 pm »
Michael,
> Can i use regular fabric to cover the back <
Yes.
--Ethan
bpape
    • Sensible Sound Solutions
« Reply #5 on: 10 Jul 2005, 12:12 am »
If you want, an electric carving knife can work very well with the right blade.
