Guidance on H.T. receivers with Optical input
0 Members and 1 Guest are viewing this topic. Read 947 times.
konut
« on: 8 Jul 2005, 11:36 am »
The iMac G5 has an optical output rated at 130db signal to noise ratio. I'm looking for suggestions for a H.T. receiver that will do justice to this signal. IOW has a quiet pre and amps with a respectable SNR. I'm aware of the good results with the Pioneer 1014 and the offerings from HK, but I was hoping there was something with a smaller form factor that would do the job. The amps need not be huge as this will be for near field listening. Good SNR is the top priority. TIA.
ScottMayo
Re: Guidance on H.T. receivers with Optical input
« Reply #1 on: 8 Jul 2005, 12:59 pm »
Quote from: konut
I'm a little unclear on what noise represents in a digital, optical output. The photons are either flowing or they aren't. Instinctively, I think this is a marketing number, not a reality. Without getting into a discussion of quantization error in digitally recorded music, I think they are (dishonestly) trying to say that optical digital outputs, being both optical and digital, introduce no noise whatsoever. That's a safe and easy claim to make, since noise happens in the receiver, when it converts the digital data back to analog.
In analog audio (like a receiver), a 120db S/N is considered phenominal, and I can't think of an amp that actually reaches it. (I've seen one claim of 115db S/N in a unit priced at 46,000$). I don't think any receivers get to 110db, let alone the 130db you ask about.
For typical nearfield, you can probably manage just fine with 100db S/N. Look at Onkyo receivers for a start. If you seriously need more, open the wallet wide and start buying separate components. Bryston amps achieve 113db S/N on a good day, and the prices aren't stratospheric compared to other high end gear. (Compared to receivers, yes, they are.)
konut
« Reply #2 on: 9 Jul 2005, 01:55 am »
Purhaps I havnt made myself entirely clear. While the G5 is capable of the 130 db spec with the appropriate hi rez media and onboard recording, with a high quality mic,  I realize it is only capable of 96 db SNR with CD. My quest is a receiver that has a higher than average SNR, in a less than monolithic form factor like the Pioneer 1014. BTW, Flying Mole amps spec 120db SNR at $375 per 100 watt monoblock.
     Thanks for the tip on the Onkyo. I will look into that.
