Hafler DH-500 Transendence Two
0 Members and 1 Guest are viewing this topic. Read 2739 times.
norbyx
« on: 7 Jul 2005, 09:42 pm »
Hi,
I am looking to buy this amp and I would like to know what are the mods made from the original Hafler DH-500. Is there a noticable better sound quality.
skrivis
Re: Hafler DH-500 Transendence Two
« Reply #1 on: 7 Jul 2005, 11:13 pm »
Quote from: norbyx
Hi,
Almost all of the original circuitry was replaced.
I'm a long term AVA customer, and I am positive that the AVA upgrades were/are better than the original Hafler circuitry.
I can say that I have an older Fet-Valve AVA amp, and it's better than a Transcendance Two amp. I have a more modern OmegaStar AVA amp, and it nicely blows away the older FV amp.
You really might want to look into buying an amp directly from AVA, rather than buying a used amp. I think you'll get better value.
On the other hand, if the T-2 DH-500 is really cheap, it's a good amp.
I recommend you do buy an AVA amp. :) But you might want to look at your options before deciding which amp to buy.
(I've been a customer of Frank's for around 20 years, and I've heard a lot of other amps. I haven't heard anything that would make me switch my allegiance.)
norbyx
« Reply #2 on: 8 Jul 2005, 05:11 am »
Thanks for the help. Well the hafler transcendence that I was offered is selling for $450 so I think that the price is fair. I couldn't affrod to spend more than $500 on an amp. I am looking for the best deal for the money and I think that this isn't bad. What do you think?
skrivis
« Reply #3 on: 8 Jul 2005, 10:22 am »
Quote from: norbyx
Yes, that's not a bad price. It's about half of what the cheapest new AVA amp would run you.
One thing you might want to do is call AVA and see if they have any used equipment. Sometimes they have some really good deals.
AVA will also check out used amps for you. It's $100 plus shipping, so I don't know if that's an option for you or not. You could have the seller send the amp in for a checkup before you buy. (AVA amps are pretty sturdy beasts though, so it's probably in good shape already.)
skrivis
« Reply #4 on: 8 Jul 2005, 10:23 am »
Quote from: norbyx
norbyx
« Reply #5 on: 8 Jul 2005, 08:13 pm »
Has anyone ever had this amp? I was wondering. I read so many good thing about this Van Alstine amps and none bad. What comparason is there for this amps quality. I mean I have read people that had krell, macs, levinson, and finaly decided to stick to Van Alstine. Are this amps really so good as every one tells?
skrivis
« Reply #6 on: 9 Jul 2005, 12:04 am »
Quote from: norbyx
I wouldn't buy it because it's more amp than I need. I would naturally want to have it upgraded at some point, and it's going to be more expensive to do so than with a smaller AVA amp.
But it's still a very good amp and it has great gobs of power. But it won't be like some big amps that don't have any subtlety.
I'm sure there are people who say bad things about AVA products. But you're not that likely to find them here in the AVA circle.
People who own expensive amps like you mention and then hear an AVA amp realize that you don't get better sound for your money with the other brands. Most people want the best value for their money, so they become loyal AVA customers.
I'm not going to tell you that this AVA amp you're thinking about is the best in the world, but it was very good indeed when it was new. You might want to look at: http://www.avahifi.com/root/review/t250_audio.htm  This is a review of a lesser amp from the same series, and it's in a major magazine. There are plenty of other reviews of AVA equipment listed at: http://www.avahifi.com/root/review/index.htm
All I can say is that I've been a customer of Frank's for around 20 years, and I won't buy anything else. I also recommend AVA to my friends.
It sounds like this amp at $450 will be a major purchase for you. Maybe your comfort level demands that you buy something else, maybe something that your friends recommend? You can always explore AVA products at a later date.
You really should try giving Frank a call and asking him for a recommendation. Maybe he can suggest an alternative. Or maybe he'll think this is the best amp for you and your budget. He won't lie to you. You can trust Frank and _that's_ the bottom line for me.
