0 Members and 1 Guest are viewing this topic. Read 1264 times.
I've checked my JVC F10, and indeed the negative speaker output terminals are not tied to the ground. Interestingly, I also checked my PartsExpress plate amp, and the negative (black) speaker-level input terminals are not directly tied to the ground but instead have a finite resistance (~1Kohm) to the ground. Perhaps that's why someone was able to connect the outputs of the JVC F10 to the speaker level inputs of a sub plate amp without shutting down the JVC. I guess the maker of the plate amp anticipated that some people will try to connect balanced amp outputs to the speaker-level inputs and designed the input circuitry to cope with that.
