0 Members and 1 Guest are viewing this topic. Read 2480 times.
Also, I do not want a real dipole, only hole(s) allowing to let the wave-pressure "escape" out of the inside.
I believe that the point source is the best system to get right soundstages and image; so, no open baffle for me.
What does point source have to do with open baffle or non open baffle?
You can also dampen the rear wave of an open baffle if you are a little creative
I added some absorptions to the rear wave coming from the open baffle midrange unit...result...a little gain in clarity, at the cost of dynamics and spaciality, so I decided to leave them out.
