0 Members and 1 Guest are viewing this topic. Read 14733 times.
I was also wondering if Brian had any comments on placing 2 626's together (one on top of another). QuoteHi John,Although I have not discussed the positioning of the tweeters (if they are close enough when stacked) with Brian, but apparantly he alluded to the possiblity somewhere and Doug mentions it in the post below from HD.Doug S. said the following:brian cheney *did* say that a pair of 626r's per side, w/the top one stacked upside-down on the bottom one, on short stands, to get the tweets at ear level, would work quite nicely, assuming proper bracing, etc... http://www.harmonicdiscord.com/forums/viewtopic.php?t=5902&highlight=stacked+626rRegards, John Casler VMPS LA CA USASUMMIT Audio Video310-446-0138800-320-6884 (order desk)[email protected]http://www.audiocircle.com/index.php?action=systems;system=72http://my.register.com/summitaudiovideo.com/index.html
New tweeter make a big improvement over the stock ?
The BOLDER Cable Company will be showing and playing the latest version of the VMPS 626R with the FST tweeter at the Midwest Audio Fest.
I live in Columbus, we can probably figure something out.
Which is the recommended setup? (please weigh value for the buck) 2 626R's on solid stands with a single dedicated sub on the side. 2 626R's on top of dedicated subs. 4 626 R's 2 on a small solid stand, one on top of the other, but upside down. Also, should the 626R on top of the dedicated sub be upside down?
They are especially good if they have a "slant" to them for the bass wave to slide down...
Quote from: John CaslerThey are especially good if they have a "slant" to them for the bass wave to slide down...JohnSlant toward listener or away? I thought the beard sounded better on the back panel where the port is, vs. the front. Have you tried both positions?
