Will DACT CT2 replacing the L-Pad improve Performance?
0 Members and 1 Guest are viewing this topic. Read 1872 times.
woodsyi
I want to retain the control aspect of the pot and am wondering if these units would be a significant improvement over the stock units.  If so, what impedance should they be ordered with?
http://www.diycable.com/main/product_info.php?products_id=456
P.S.  Will this void warranty?
tkp
« Reply #1 on: 5 Jul 2005, 01:40 pm »
The DACT CT2 was designed for small signal so there is a limitation to how much current the Elma switch inside the CT2 can conduct.  From the DACT website, the CT2/CT1 can conduct the following current without significant loss.
2V/2A
24V/0.6A
42V/0.4A
IMHO, the CT2 cannot be used as LPAD attennuator for speaker level signal.
If you are handy, you can easily get a high conducting current switch with a lot of positions (iel..24, 48 ) and build a high quality LPAD using high wattage rating resistors.
Kevin P
    • http://www.diycable.com
« Reply #2 on: 5 Jul 2005, 03:16 pm »
Ditto.... the CT2s are for line level signals only.
woodsyi
« Reply #3 on: 5 Jul 2005, 04:23 pm »
Kevin,
Glad you chimed in.  Do you have a high current stepped attenuator kit or parts for making such?
Kevin P
« Reply #4 on: 5 Jul 2005, 04:49 pm »
Quote from: woodsyi
Kevin,
Not at the moment.   Some of the Shalco switches are big and beefy but I've never researched it in detail.    It is something I get a request for on occasion.   Not so much that I've ever had the urge to find a product to fill the niche.  :-)
