Phil,
> I do think bi-amping is quite effective when done right <
No kidding. My big JBL speakers are bi-amped and even I can hear the difference.
But bi-wiring irritates me because it's a useless "pretend relative" to bi-amping which is legitimate.
> whether it's because it couples or decouples vibration, or if it's simply because it puts space between the bottom of the speaker <
I agree decoupling can be useful. And changing the woofer-to-floor difference can surely change the sound. Now, changing that distance is just as likely to make the sound worse, especially if the speaker designers know what they're doing and optimized the woofer height. So in that case you might hear a change and wrongly assume the response is now flatter, even though it's really less flat. Likewise, if one of the many inevitable peaks or nulls shift frequency, and the result is at a musically pleasing frequency, then it might sound "better" even though it's technically worse.
For example, 200 Hz is a kind of "woofy" frequency, so a spacing change that decreases output at 200 Hz might seem to sound better on some material. Or maybe a reflection due to speaker-wall spacing created a slight peak around 400 Hz, which is a "boxy" sounding range, and the added height knocked that back down. Or the change increases output at 80 Hz which adds a nice fullness even if it's less accurate. (A lot of people run their subs at +6 because they simply like the way that sounds.) So changing the speaker height might be better, or it might be worse. Or it might make such a small change as to not matter.
The only way to really know is to measure both ways using something like ETF. If any of you guys have ETF and are willing to run a few tests, I'd love to see the before and after graphs. That would go a long way toward convicing me that spikes make a useful improvement. It might also give
you some ammunition for the future when this comes up again. And it surely will.
And finally: I never said speaker spikes are useless! I honestly don't know. What I have said, and will continue to say, is that isolating
electronic gear is useless. Especially for anyone listening in an untreated room, where room reflections damage the sound 100 times worse than any vibration possibly could.
--Ethan
